-   -   Need some opinions (https://www.ft86club.com/forums/showthread.php?t=142465)
ben w 09-20-2020 08:55 PM
Need some opinions
I’m doing some upgrades on my 2019 BRZ and I have a couple questions
Which invidia is better (sound wise) N1 or Gemini R400 and which injectors do you guys recommend for a stage 2 remap
Ultramaroon 09-20-2020 09:23 PM
Stock injectors are good up to stage 2.7 for all model years except 2019.
ben w 09-20-2020 10:21 PM
I was looking for a brand or cc range mate
x808drifter 09-21-2020 12:38 AM
:sigh:
Brand
OEM
cc Range
OEM
The stock fuel system is MORE than adequate for the car in N/A
ben w 09-21-2020 03:39 AM
Originally Posted by x808drifter (Post 3368983)
:sigh:
Brand
OEM
cc Range
OEM
Will be boosted it soon tho
x808drifter 09-21-2020 06:02 AM
Then WTF do you even mention "Stage 2"?
Stage 1 Hardware Requirements:
OEM header. *Any exhaust modifications after the header is also compatible
Stock Airbox (with or without aftermarket drop-in panel filter)
Premium grade fuel
Stage 2 Hardware Requirements:
Aftermarket CATTED header. *Any exhaust modifications after the header is also compatible
Premium grade fuel
Stage 2+ Hardware Requirements:
Aftermarket CAT-LESS header. *Any exhaust modifications after the header is also compatible
Premium grade fuel
Stage 2+ (E85) Hardware Requirements:
Stock OR Aftermarket CATTED OR CAT-LESS header. *Any exhaust modifications after the header is also compatible
E85 fuel ONLY!!
There is no OTS "stage" that involves boost.
This isn't a WRX/STI
Ultramaroon 09-21-2020 04:55 PM
Precisely the reason for my equally informative first reply. Garbage in - garbage out
Ben, if you spend some time perusing the tremendous history here, you will find answers to your immediate question. Hopefully, you will also end up with many more questions which, if asked in conjunction with a decent attempt at providing relevant details, I guarantee will get you many enthusiastic, well informed responses.
Welcome to our awesome forum! We like to keep it real and enjoy the banter.
JD001 09-21-2020 05:36 PM
The opinions expressed so far are rather one sided.. need less bias or should that be more bias?? Oh I don't know... Welcome your opinion?
Aztec 09-24-2020 04:01 PM
Regardless of the lack of a bit more context i'll try and help you out.
No experience with R400 exhaust, but he Invidia N1 is the loudest catback for the 86 platform, if you run any kind of aftermarket headers you WILL have drone on the highway. A good sounding exhaust that is NOT restrictive AND shouldn't drone when combined with a header is the Invidia Q300, look into that one.
Injectors & fuel pump is only required to be replaced when you introduce a turbo or E85 and supercharger. Generally at that point (300whp+) you are going to start replacing a slew of parts such as clutch/axles and worrying about the reliability of the FA20 unless you change the compression/build the engine for the boost.
All of that said any mods on an NA build or a very low boost application, the car is VERY reliable. Easily anything below 250whp should be safe assuming the tune is well made.
HaXx 09-24-2020 07:10 PM
not gonna lie the N1 with the rest of the system stock is still a little bit loud. depending on your climate, i feel kinda bad letting my car warm up in the winter months, its noise is just on the border of being too much, but i still warm it up with no neighbor complaints.
