-   Suspension | Chassis | Brakes -- Sponsored by 949 Racing (https://www.ft86club.com/forums/forumdisplay.php?f=59)
-   -   Refreshing the suspension and brakes on an older BRZ/FRS/GT86 (https://www.ft86club.com/forums/showthread.php?t=142230)
Racecomp Engineering 02-16-2021 02:15 PM
Originally Posted by RickyRacer (Post 3406581)
I need to replace the rear subframe / diff bushings on my car.. but after watching how-to's i realized this is outside my paygrade and i don't have the necessary tools
A shop will be doing the bushings for me. Is there anything else I should have them replace while the rear-subframe is out?
I can do shocks and end links and LCAs and what not myself.
but any parts i can hand them while they got the subframe bushings out that would be worth while?
all parts will be OEM from Toyota. Thanks
Possibly the upper control arm bushings. Or the full arm assembly with ball joint (possibly easy enough to do yourself, but super easy if you have the subframe out).
- Andrew
RickyRacer 03-04-2021 09:43 PM
just realized the subframe bushings themselves dont come with the rear subframe (which includes the DIFF bushings)
Are you supposed to swap out the subframe bushings?
ItsReiko 05-14-2021 03:29 AM
Should the front strut mount/tower bolts/locking nut/upper & lower strut bolts be replaced or reused when installing a new front strut?
