-   Suspension | Chassis | Brakes -- Sponsored by 949 Racing (https://www.ft86club.com/forums/forumdisplay.php?f=59)
-   -   Snap oversteer??? (https://www.ft86club.com/forums/showthread.php?t=141224)
mamamiaellis 07-01-2020 07:12 PM
Snap oversteer???
hi guys,
So i have had this issue with my car at the track.
Around sept of last year my set up was
Custom coilovers
Hankook td
Alignment -3 front -2.6rear
This setup felt great. No issues.
I went to the same track same config this past feb before covid
And my car felt like it was on glass. No other cars were have this issue.
My car on every corner exit would snap oversteer like crazy. I thought it was my garbo driving, but i had a buddy drive my car and he said something is definitely off.
In between track days, i hit this HUGE pothole on the 10 freeway....like this pothole was so big i honestly felt my wheel cracked.
My gf thought we crashed.
Oddly enough i got an alignment, my guy says the alignment was spot on.
All suspension arms and bushings looked great.
What could cause my car to behave so radically in corners?
Any opinions would be much appreciated.
I hope it isnt frame damage. I would literally be okay with any other damage lol
Track was streets of willow cw.
Thanks for you help in advance everyone
p1l0t 07-01-2020 07:30 PM
Too soft? Causing too much weight transfer? I'm the wrong to guy to ask though thinking back to my go kart days as a kid.
mamamiaellis 07-01-2020 07:58 PM
Thanks for the response.
Not sure but all i know is my set up was exactly the same both times i went. Only difference is me hitting the pothole
BlueWhelan 07-01-2020 08:51 PM
Did the pothole cause internal damage to the damper?
Did you get the alignment before or after the car felt wonky? Could have left a bolt loose, or maybe you cracked a cam bolt or something and no one could tell because they didn't remove anything. Weirder things have happened.
soundman98 07-01-2020 10:01 PM
Originally Posted by mamamiaellis (Post 3345780)
...Custom coilovers
what custom valving do you have? i would first talk to your shock guy.
Ernest72 07-01-2020 10:21 PM
How were your tires? The same ones, more wear, tire pressures?
strat61caster 07-02-2020 03:34 AM
+1 tires get old, grip less
Some tires get noticably worse sitting in the garage during the "winter" months
mamamiaellis 07-02-2020 05:01 AM
Soundman98
I trust my shock guy. I dont think its the problem. He drove my car too and he said they felt fine.
Strat61caster
I did have my tires sit in my garage over the winter.
I live in socal so its not that bad. But maybe letting the tires sit ruined them?. Never thought of that.
Ernest72
Tire pretty i was running were the same as my first mentiined track day. They still had life left. They are my second set of wheels. So they just sit in the garage not used unt track days. Same tire pressure. Slightly more worn, but not nearly enough to make the rear feel like its on glass.
BlueWhalen
I got an alignment before and after. everything seemed fastened down.
Thanks everyone for your opinions. Really helps.
Also i got an alignment and new dd tires. I used tk daily federal rsr. But switched tk their higher TW tire. Their new ST-1 evoluzions.
If i turn the wheel back and forth at highway speeds, the rear feels super floaty.
Maybe i have been blessed tk drive on higher grip tires. But my friends cars who has way crappier tires dont feel like the rear is floating and trailing behind when i make inputs with the steering wheel. Not sure if this problem ks related to my oversteer issue.
But my alignment guy as i mentioned before says everyhing "looks" fine.
churchx 07-02-2020 07:16 AM
Ar all suspension bushings/connections/linkages really fine? Wheel bearings? Are all bolts checked from both sides? (had once head of upper camberbolt snapped, somehow noticed it only when changing winter wheels to summer ones. "it drove fine!")
Do you have by chance alignment printout? Imho more often then not misset toe may cause handling artifacts then camber that you mentioned.
Though that's more along the lines "check everything". By Murphy's laws it will probably be something obvious that noone thought to check or checked last :), just like i checked everything in suspension multiple times in search for noise source, and it turned up loose bracket connection of braided brakeline :/
p1l0t 07-02-2020 07:20 AM
Sounds like maybe the gas leaked out of one of your struts/coilover/shock absorber whatever you got in there.
Azzudien 07-02-2020 10:14 AM
Do you have any additional tire noise while driving? You could have broken belts in the tire causing your sidewalls to crush more than normal in a high g turn. Had this happen to me and drivers side rear sidewall was flexing huge. Car behind me caught it on camera.
Toyo R888R's
Same thing, large pothole on way to the track. 2 laps and my track day was over the car was so bad.
churchx 07-02-2020 10:22 AM
Azzudien: and let me guess - on stationary car tire still looked normal, as damage was inside?
mamamiaellis 07-02-2020 01:23 PM
Thanks for all the ideas.
I really hope my struts arent leaking.
XD
As for arms/ linkage, i am totally fine with bent or broken arms /bushings sonce those are replacable.
Im just hoping no one says its frame damage. I am thinking of going into a shop to inspect as well.
Azzudien 07-02-2020 01:40 PM
Actually the sidewall will starting bulging in some instances. You also will feel it driving. It got substantially worse as I limped home, there was a lot of vibration though never saw any bulge until the tech pulled tire off the rim and he showed me a large bulge inside the tire.
Never heard of it before it happened to me. And frankly I didn't believe the guy at the track that told me this until the tire tech pulled the tire off and explained it all. Apparently not that uncommon in the northeast with our crappy roads
