| M0nk3y |
07-30-2020 02:25 PM |
Originally Posted by Grady
(Post 3353432)
It is just open cell thin black foam tape. It just keeps it from metal to metal contact. You may check with them to see if they recommend it. Since it is in beta they may have not completed the install instructions yet.
I didn't receive any open cell foam tape, all that was pictured was in the OP. With that being said, it's not a bad idea...I'll go ahead and grab some.
Originally Posted by NoHaveMSG
(Post 3353439)
I noticed the Verus wings mount out towards the edge which is why I ask. I have an APR that mounts in the center and it tends to twist the leading edge of the trunk lid up quite a lot under load.
I'd be more than happy to get a video pointing backwards during a session next weekend (Aug 8th at NCM) to see if there is any massive deflection. Statically, trying to replicate that movement the trunk is pretty solid. IIRC from other people with other wings, older hinges that have seen some wear tend to have more play which may account of the shift under load.
Regardless. I'm going to NCM with R7s this time around and there are 2 high speed sweeper present.
On street tires, T5 I was entering at 105/103 sustained and T16 which is a mid/low 90 MPH entry to a 97ish MPH exit. If anything is going to deflect, it'll be there.
https://www.youtube.com/watch?v=57UaiKO9zFM
