1UZFE Swap
So I want to do a 1UZ swap, obviously there痴 no kits available on the aftermarket for this swap (I致e done some pretty extensive searching [emoji23]). I have a buddy who works in the CNC industry that can fabricate most of the parts that I need. That being said, is there anyone on this forum that has done this swap or knows about this swap that could give me some help? I知 specifically looking for a parts list, what was left stock in the engine bay, what modifications to the engine bay were done (steering rack, clutch slave, etc), and specs (blueprints would be even better) for engine / tranny mounts (I will either be using a CD09 or an R154 transmission). I plan on using a Haltec ECU to communicate with the stock CAN system.
I am pretty sure the HP academy guys have a 1uz FRS that they track. Maybe they have some more details you could go off of?
https://www.hpacademy.com/blog/wirin...oject-panhard/ |
I had seen that. I actually reached out to them and unfortunately they said they had very little to do with the actual swap, which is what I知 most concerned about. Sent from my iPhone using Tapatalk |
For transmission, if you are looking into the R154, take a look at the AR-5. I will be using one in my LS swap. Its basically indetical to an R154, just with some Chevy parts bolted on. (and typically a lot cheaper) There are 1UZ trans adapters out there. Pretty sure Motec ECU would be the best way to go to run the 1uz, and maintain CanBus of the stock FRS electronics. As far as actually mounting the motor, I can't help at all there. It may be time for you to go to a junkyard to pull a motor and start a mockup. |
I have reached out to the original owner of the vehicle and several others on this forum who have actually done the swap. Unfortunately none of them have gotten back to me yet, it seems most of them have been long since inactive on the forum [emoji53]. I think you may be right about pulling the motor, I知 trying to go for minimal downtime on my build tho bc I like dailying my FRS. Perhaps I should find a junkyard motor and cut the subframe / engine mounts out of the original car and see how they compare to the FRS? That could give me an idea of what I知 in for before I need to take measurements and pull the Boxer engine. Sent from my iPhone using Tapatalk |
His youtube videos are still up, just go to the URL in the initial posts. Looks like he had the mounts done by Surfab. Their website doesn't show anything, but maybe try reaching out to them as well? |
I have looked through this thread, I want to get fab info out of the way but my greatest concern is modification to things such as the steering rack, whether I need another clutch slave, and how many of the 1UZ or FA20 engine accessories will I use and which ones from which engine. Just the little bits and pieces that really hold you up when you get to them you know? Great idea to reach out to surfab, I just emailed them to see if I could get any help / information on the swap from them. Sent from my iPhone using Tapatalk |
You won't be using the original gearbox, so you'll use the slave etc on the new box. There's a few possible options: T56/TR6060, Toyota R154, Nissan CD00x (requires trans tunnel mods)
You'll be able to leave the steering alone You will use the accessories on the 1U, minus the p/s pump (idler in its place). Engine management you can go Motec, Emtron, ECUMaster, or now Haltech (I'm going Haltech) Surfab didn't reply to me when I sought info about the mounts. I'll be making my own. Exhaust manifold is going to be custom too, but I believe you can get away with using the smallest of the stock headers, they're just a bit shit. |
Thanks for the link but it doesn稚 seem to be working? [emoji848] Sent from my iPhone using Tapatalk |
Let me know how fabricating the mounts goes. I figured on having to take the idler pulley and slap it on the 1UZ bc of the electric power steering. I had no idea there was a conversion plate for the T56, that makes things a lot easier. Sent from my iPhone using Tapatalk |
FRS/BRZ/GT86 Enthusiasts A picture from his post.... |
I gotta promote the AR-5 as a transmission option. With an AR-5 out of a solstice/sky the shifter is in almost exactly the right location, and 1uz adapter plates exist for the AR-5
I am very interested to see what you figure out here for mounts and wiring. |
| All times are GMT -4. The time now is 11:24 AM. |
User Alert System provided by
