Konig Ampliform in today. 17 x 8 40 are weighing 17.3 lbs. PS4S 235/45 due in next Wednesday...should be near or under factory wheel/tire weight.
What's this???
Tires mounted, center caps on...
3 Attachment(s)
From factory 215/45-17 to 235/45-17. New wheels/tires save 2.5lbs per corner. Color is close to the factory bronze:
Just wondering why you wanted to go with such a noticeably taller tire size than stock? Sure combo weighs less than stock, but you are decreasing responsiveness in acceleration/decelleration by that diameter gain. Looking for better highway cruising ability with the new shorter FD?
Bilstein PSS10
3 Attachment(s)
I verified that preload was set to give the full 30mm drop. The ~9mm lift from the larger diameter tire off sets the chassis drop to ~21mm, close enough to the 20mm starting point I have in mind. Baseline height measurements were taken on the stock setup. Each corner was loaded with a floor jack, prior to torquing down rubber to metal joints. Added some grease to the front axle top hat ball bearings while I was in there.
2 Attachment(s)
Cool that they thought to notch the deck panel in the trunk for damper adjusters. I just used a sharp knife to cut a "X" for the shock shaft.
Konig Ampliform 17x8 40
7 Attachment(s)
I've got about 100 miles on the new tires/wheels & coilovers. I'm going to fine tune ride height before aligning, and car has settled a few mm since yesterday. On rougher roads, I'm into the rear bump stops more than I like, so I will raise the car ~10mm and see how that feels. The goal here is a compromise: firm (not harsh) street ride that's till fun for the occasional track weekend at COTA.
Anyone know where I can buy the TRD lip spoiler pre-painted Hakone green?
BTW, here's my 1st 86 journal, from 6/2012: https://www.ft86club.com/forums/showthread.php?t=7934
86 Suspension Set Up
This thread is the best reference I've found on suspension set up for the 86/BRZ: https://www.ft86club.com/forums/showthread.php?t=131052
I'm currently feeling out ride height on the new coilovers, and the info there is very helpful. Now I'm making decisions about alignment. My car may see the track 2-3 times a year, so I'm wanting a livable street alignment that's tolerable on track. Do you guys find dropping a few mm of ride height on the drivers side helps with road crown? How significant would the affect on grip be left to right? I still have the worksheets for alignment & corner weight from my NC Miata. Anything to watch out for using those specs as a baseline for the 86, other than the more limited adjustability? I am running the OEM camber bolts up front. After starting with the pre-set 30mm max recommended drop setting on these coilovers, and raising the car twice now, I'm between your height recommendations for street and track. Car handling/drive have improved with each incremental increase. With the car dropped below the 949 recommended pinch weld heights (stock on my car was ~153mm at all 4 corners), running 17x8 +40 with 235/45s, the car was into the rear bump stops waaaay too much on my local roads. The pic below was ~133mm front, 142mm rear, measured at the pinch weld jack points. |
| All times are GMT -4. The time now is 08:26 AM. |
User Alert System provided by
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
