-   -   Is the Perrin CAI going to fit the AVO Turbo Bolt on? (https://www.ft86club.com/forums/showthread.php?t=139488)
Flasher 03-21-2020 06:57 AM
Hey guys,
I've been having the AVO turbo kit on my 86 now for several years, using the stock airbox and it's still going strong with 330 hp at the crank.
As the stock airbox is a tight fit with the oilcooler sandwich plate I'm looking into replacing the stock one with something different. I've been always interested in the Perrin CAI so I'm wondering if this is going to fit bolt-on.
Is the outlet of the Perrin CAI in the same position as the one of the stock airbox?
Jwood927 04-06-2020 03:35 AM
I have seen a couple of avo kits with Perrin cold air intakes and apparently mishimoto ones work as well
Sportsguy83 04-12-2020 07:57 PM
I had the Perrin CAI with the AVO kit (years ago probably in 2014). If I remember, I needed to make a bracket adapter because the bracket that holds the CAI was just a bit off. But it did work.
