ATS BBK upgrade
Can anyone confirm whether the ATS Brembo upgrade will fit under 720Form 17x 8 wheels? It’s a sweet mod but a budget breaker if wheels (and tires) are added in.
I’d hate to buy the adapter kit and calipers only to be disappointed to find clearance issues. I also have the FRS OEM RS2 wheels as an option. Thanks for any constructive information. |
Look at RR racing sport kit. Ask for no rotors and buy centric sti 2004 rotors. Just as cheap but better biased and these for behind my 17x8 et 40 hypergrams just fine. I run 3mm spacer just extra space but is not needed. Then add there rear sport kit to complete the kit. Rotors are the stock PP OEM rotors but centric has finally come out with these. Check the RR thread for the exact part number.
Sent from my GM1915 using Tapatalk |
The ATS fronts paired with the EVO X rears seems to be the correct bias according to discussions elsewhere here.
This solution is far less expensive when pieced together than any packages for both F & R. Especially when paid in weak Canadian dollars (+~36%). |
| All times are GMT -4. The time now is 09:37 PM. |
User Alert System provided by
