you can t even remotely compare turbo with sc, totally different managing of the boost, you have a wastegate working for it, sc boost depends entirely on pulley, restrictions and iat temperature
Both of those logs I posted are from the Supercharged FRS. One with First one was with Tomei UEL, second one with stock header with cat...... I own both cars Supercharged FRS, and a Turbo BRZ. I'm focusing on the supercharged FRS which those two logs are from. |
I personally never ran the 90mm pulley setup that came with the kit, so no logs to compare to. I remeasured the 30mm pulley set along with verifying dimensions for the c30-94 and everything is exactly what should be a 9 psi pulley set. At this point I am either pulling the kit and selling it, switching to e85 with the upgraded injectors I have available, or figuring out a reasonable way to reduce boost. |
I usually don't rev past 7200 anyway, but maybe I can get the tuner to move it so it doesn't go more than that. I haven't heard back from Bill yet, but when I do I'll bring up some of the concerns to address. Most of these pulls were done I think around 40-50 F so it definitely wasn't super warm. |
Super strange that we have a similar result, especially considering that all you changed was going back to the stock header. |
Just to make you think about the influence of IAT on boost, during summer with 30+ Celsius i get 0.86-0.87 bar of boost from my unrestricted hks V2 in winter under 10 Celsius i get more than 1 Bar you get a more stable boost only with turbo, or with a restriction in front of the supercharger's charger |
So if the lean condition is taken care of, and the revs don't peak at 7500 constantly, is this still safe to run or should I be looking into ways to drop boost levels? |
if it doesn't knock... it's ok
I keep lower revs with 95ron fuel (your 91 oct) because that s just too much boost for me for that fuel your main problem is the lean afr |
I do a lot of autocross and quite a few track days, so I just want to be at a reliable power level with the benefit of not melting stuff. I don't want to go e85 just due to spending too much time searching for stations that have it available. I did that last year, but it was irritating. So it's either 91 or e85 for me.
e85 would be a lot safer at high rpm, with the benefit of the huge power bump you'd get
but then you need a flex sensor, fuel pump upgrade and bigger fuel injectors (that would also fix your lean issue though) |
At this point, you are dangerously lean on the top end, and you are straining the port injectors in general. The port injector duration is not ideal, which means you have to run larger injectors; if you want to run E85 too then that is a separate thing. Also, did you always have the Ace headers, or did you recently add them and the catless front pipe? Quote:
Stock injectors right now, but the kit I bought used came with some Deatschwerks ones that I believe to be 700cc. Not sure how to confirm that yet though, and as of right now they aren't installed. https://live.staticflickr.com/65535/...4bcfb8b3_b.jpgUntitled by hatchethairy, on Flickr https://live.staticflickr.com/65535/...11ff5f76_b.jpgUntitled by hatchethairy, on Flickr Before installing the Kraftwerks kit I was running a Tsudo UEL header/up pipe, Hooker catless front pipe, OFT tablet on e85. When I installed the Kraftwerks kit I added in the ACE A350 header at the same time. So to be clear: I bought a used Kraftwerks c30-94 kit that had the 20mm wide pulley set with 90mm SC pulley(I didn't even realize this until I started this thread). One of the idler bearings had some play in it, so I bought a new set of the 30mm pulley/belt upgrade before ever installing the kit. The only thing that doesn't match what Kraftwerks would have sent with a full new kit is the Tial QRJ recirc valve that is venting back to the intake. It has the pink 1.5 spring specific to supercharger applications. The tune is a FNG from Delicious based on the information I provided to them. I sent logs in for review, and a new tune was sent. A few days later the weather cleared, and I ran some new logs to check things out. My car stopped making power at about 6500. It was WAY worse than the logs I have posted as far as lean condition. To be sure it wasn't just the car, I switched back to the original tune they sent me. Everything acted normal again. Since then, I have sent those new WORSE logs in for review but haven't heard back yet. I don't want to knock their work until I give them a chance to help me out. I just want a safe reliable tune. |
I've got four 5 gallon cans that I used specifically last year for my trip to the track, at the track, and the drive back. It isn't completely terrible, but honestly it was kind of annoying. At least with the flex fuel sensor I wouldn't have to worry about switching tunes like I did with my previous OFT setup. So far the only thing I "think" I need to go e85 is a fuel pump, a new tune, and flex fuel sensor. I already bought a Exedy Stage 1 clutch in preparation for the jump in power. Problem is I don't have the funds right now to do anything else. In a few months I'll be good, but I owe a bit more than expected to Uncle Sam, so funds are just tight. |
As you can see, I'm getting 0.87 bar or 12.5 psi and on other pulls up to 0.89 bar or 13 psi at 61 degrees Celsius. I bought the kit off @johan and he saw a peak boost of around 11.5 psi and he lives in cooler Portland. https://datazap.me/u/jirace/v8-flex-...0&data=8-29-38 |
no, you are SO wrong mate.
Lower temps bring higher boost, the more density is indeed what causes it. Ask any tuner and you will get the same answer :) That s also why a turbo has to work harder and faster to achieve same boost with higher temp, because it produces less boost with warm air temp and to open the wastegate it needs to spin faster it is basic physics |
The reason I ask about the tune was because a header is a significant modification that I hope DT knows about. In other words, you would receive completely different tunes based on your car having headers and a FP versus having the stock exhaust setup. It sounds like they know everything on your car at this time, except, like you, they thought you were on the base pulley. Also, you were using e85 while NA using OFT on a single tune aka no flex tune setup, so you ran E85 exclusively, right? Or a dual tune, and you would completely deplete your tank then run 91/93, right? You don't still have E85 in your tank now, right? |
Man, you are thinking wrong.
Cold air increases boost in a supercharged engine, I have like 350 logs in my datazap of different sc cars and turbo I tuned that could prove you wrong but still I ll enjoy the dinner with my girlfriend instead of searching for them. It s a very basic thing actually, ask a reputable tuner since you won t trust me, and let me know what they ll say ;) also, who talked about power? not me Power is relative, yoy can have more boost and make less power if the fuel doesn t hold the pressure and knocks |
Yeah they were given all the info on exactly what I have installed. I can only assume they read what info was given to them though. I've never and still am not running any pulley other than the base 95mm pulley. The 90mm pulley has never been under the hood of my car, and I have confirmed the 95mm pulley I have installed is exactly 95mm. I know this shouldn't have anything to do with it, but my car is a 2013, but the engine/trans is from a 2015. Previous owner of the car had the valve spring let go, dealer told him to kick rocks, and then installed a low mileage 2015. As for previously ran e85, you are correct. I ran an OFT UEL stage whatever for e85 all spring and summer. Once we got chilly weather here last fall, then I switched over to 91 or whatever standard tune. I've run probably 5-10 tanks of 91 since then, so none should be left in the system. |
Captain awesome, your boost curve has nothing wrong, your kit has nothing wrong. You only have a shitty tune and bad fuel delivery and/or maximized PI
Anyone have a tuner to recommend other than Delicious? Not ready to jump ship yet, but if the radio silence continues I'd like to have someone lined up and ready.
Irace, remember that an engine is VOLUMETRIC but the fuel supply is managed by the MASS of the air
If you are a "science bitch" you would know what that means, and why hotter air and higher altitude bring the boost down |
I think we would both agree that if ambient air was fixed then if we saw a drop in manifold air temperature with the addition of say/hypothetically a better intercooler that this would result in less boost pressure, which I know is a different scenario, but just for clarification. |
I think DT is not raising your DI because it screws up their maf/SD precompiled that they have for every car, all the same for everyone and they let Ecutek closed loop control to work instead of them :P
there is no problem in raising DI opening near 5.5ms or even 6ms, it just changes things because the 2 fuel system are not well scaled and calibrated already from factory Just a question... Normally how many Releases do they take to complete a scaling/remap? not counting the extra like racerom features... DI in our car has a loot of headroom... what, they think DI is bad? and subaru engine that have only DI should explode? DI has a great capacity in our car and we can take advance of it I have people regularly tracking with 1Bar of boost and DI opening at least of 5.5ms trhough limiter, and no one has had problems in years, indeed they have high ignition timings and leaner afr compared to yours and no knocks, and powerful cars. |
I just want to add that as far as temperature goes, I have had several turbos cars I've driven from 100 degrees F to -20 degrees F. In 80 f, my 3000gt vr4 and 02 WRX felt moderately quick. At 30 degrees, they are brutal- the cold air being denser and the low IAT gives much more torque and boost builds much quicker, it's incredible.
A tune meant for summer will run lean in winter. |
Turbo is too different, and anyway you have tables and custom maps in ecutek that you can use to manage the difference in iat for the afr
besides that, turbo will always be tied to the wastegate, so you won t see an increase in boost but it will spin lower to reach that that s also why, if you raised the maximum boost with an EBC, you usually make a turbo boost less than what you do at sea level, because the less denser air would make the turbo aggressively spin too much and even overboost more than the desired target if not well managed Anyway from june 2018 (racerom 10 and above) every tuner uses the closed loop fuel control, like DT does, and your are pretty much on spot with the afr at any time, both closed and open loop, it basically transform the car in a constant closed loop state without the limitations of the subaru closed loop strategy |
They ask for a log then do a revision most often after each log. In total I had 8-9 revisions. I had an idle log, another idle with different rpms, a steady state cruise log, a few tip in logs, a bunch of 2k to WOT/redline logs. I did add larger injectors and a flex fuel kit along the way at no extra charge because I bought them in the revision phases to get my fueling right like Captain Awesome. His duration was already 5.6ms. I agree that other cars must have a longer duration because they don’t have D4S and only direct injectors, but what size are their injectors and what is their duration? |
But not sure. What i am sure of is, colder AMBIENT temperature will surely bring more boost to the manifold |
Anyway from the logs, after he reaches 5.6ms, it goes down... it could be made like 5.8-5.9ms or 6-6.1 in cold weather, to redline, and there is a trick i only see used by european tuners, to overload the high pressure fuel pump to 22psi instead of 20psi (or bar? whatever the unit for it is) at high loads and that would bring down the PI usage.. it increases parasitic loss, yes, but the benefits override this, and also cools more the charge and increases detonation threshold... win-win the stock mapping for High pressure fuel pump, reduces the pressure to 18 at redline to reduce pumping/parasitic losses because NA this car is already too slow :P but with boost and more than 300 bhp you do not care about that loss at all... damn, you almost don t even care of the loss that carrying a belt driven charger brings... About the F1 engineer... they work with 20000rpm with narrow band of torque, in a range of rpm that are so high that is known the DI brings disadvantages.. our engine has MUCH lower rpm and i do not see or ever had a problem in raising the DI usage, stock DI can easily open more than 7ms at maximum nominal pressure without bringing fuel delivery issues, 6ms is not THAT much, as soon as you keep an eye at the time between end of injection and the spark firing and keep it more than 1.5-2ms away.. and we can even modify the DI firing angle to avoid that |
yoy do not look only at cc size with DI because it depends also on high pressure provided to them
and 20-22MPa gives you a lot of fuel, even if you are only limited to inject in a window of half the time , compared to PI that can inject at any time And our DI delivers LOT of fuel if you want.. and remember that the fuel passing through cools the injector, and they are off for 2 stroke out of 4 PI is potentially more prone to overheating Until 7ms of opening at 20MPa, it doesn t lean out, meaning it provides the fuel needed, so 6ms is a reasonably limit for a cold weather situation, just need to watch you are away from the spark a couple ms at high rpm I logged my car in NA form time ago, first with PI disabled and then with DI totally disabled with DI it works all the time providing all the fuel with only PI you reach 20ms of opening at like 5000rpm, leaning out like the log of OP |
Guys, colder air is denser, your balloon analogy is the opposite in this case.
Colder air = denser, = more air into the engine = more fuel to compensate the ratio = more power. |
No additional upcharge for injector scaling or ethanol, if you happen to have either of those. Includes as many revisions as needed to make the car run to Zach's satisfaction. Also, quick turnaround times! |
Sounds good. If I don't switch to flex fuel until later, what kind of revision charge would that be? I know I'm going to add it in at a later date, but it's going to be a few months. |
| All times are GMT -4. The time now is 06:52 AM. |
User Alert System provided by
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
