I thought E85 engines run cooler?
If it's still misfiring after these new coils, then it's clearly something else, and I'll start digging into the fueling system and perhaps see if its something internal like a bent valve prior to me buying the car. After building this car, it's clear the chassis is phenomenal, but it's clear you can't sell a mass produced, inexpensive sports car without cutting some fat. There are a lot of things on this car that are "just good enough". We cracked open an axle this week to rebuild them and pack them with high-temp CV joint grease, and the OE lube looks like water. No clue how it lubricates. No wonder people blow axles all the time. Only way to find out is get out and run some flyers! |
Needed to do a quick systems check prior to taking it to the track. Also had a newly rebuilt/upgraded tranny, along with a lower 6th gear ratio installed, so wanted to see how that felt.
There are some deserted backroads where I store my trailer, so was able to do a few hard acceleration runs. I didn't have any active (flashing CEL), or stored (CEL staying on) misfires on acceleration runs, and I ran the car to almost the top of 6th gear to 130mph. In the past, the car would misfire on acceleration around the top of 4th, and in 5th or 6th gear. Sometimes you could feel it, other times you couldn't, but the CEL was still flashing, and would stay on after. The good news is that I didn't see any on these acceleration runs, but won't claim victory until a full weekend on-track test is completed without misfires. Car felt super strong though. One thing I did see though, atleast I think I did, as it happened so fast, was a the CEL flash quickly just a couple times on a massive deceleration/braking phase after a run to 125mph. I was bedding in some rear rotors so gave it a good hard stop and thought I saw the CEL flash. I'm wondering if this could be due to the massive forces on the crank, and it's sensor readings due to deceleration? I have a Fluidampr harmonic damper, and it's a viscous type, so it's forces may change a bit with crank speed I would imagine. I'm guessing that it's possible and not an ignition related CEL/misfire, since it's in deceleration. I know Subie motors are sensitive to crank position, so I think it might be related to harmonic damper/flywheel. Any thoughts? My plan is that if I have any non-ignition type misfires or flashing CEL's at the track, then I'll swap the OE harmonic damper back in and see if it makes any difference. |
@prandelia do you have a log?
I guess I could just go run the test again with data, since it will be another 3 weeks before I'm on track. |
2013-2014 coils have a flat 3 prong electrical connector. mid-2014+ have a triangular 3 prong connector. |
@prandelia Any updates?
Another data-point here, I too am struggling with on-track only misfires at the top of 4th. 2017 BRZ w/ ~48K miles, FBO E85.
Really hoping to hear if the coilpacks solves the issue. Also, looks like Delicious Tuning has a set as well: https://www.delicioustuning.com/node/959 |
I wonder who the oem is for DT.
Sent from my GM1915 using Tapatalk |
In my head, coilpacks getting overheated is the issue. Having a ceramic coated or wrapped header may help this issue. (I'm still searching for a JDL 4-2-1). If i have more issues this year, I'm just gonna get those coilpacks and then report back! |
| All times are GMT -4. The time now is 06:08 AM. |
User Alert System provided by
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
