I didn't know they had this in 5 gallon pails, how accurate is this information? If so you just need to buy a measuring device so you can measure 32oz of additive each time or whatever your tune calls for. |
No significant advantage unless gas used is under octane required. :thumbsup: |
I added a can of 16 oz Boostane Premium in a full tank of 94, it doesn't help per the tuner. I am thinking to pour another bottle of Premium and see if it works. |
Torco always brought up the octane sufficiently with bad gas, the lower the octane the greater amount of TORCO. The most I have ever used to stop knock was half a can. Normally it only takes a few ounces with under octane fuel. I can see the knock values drop as the fuel reaches the plugs until the IAM reads 1. I still only use Torco. Remember- the fuel lines are full of lower octane gas if the previous user didn't pump 94 and I don't wait and watch to get behind someone who uses 94 - hence the Torco. :cheers: |
I try and let my car get down to around 1/3 or 1/4 tank so I can sufficiently fill it with the most 94 possible. I deal with the same issue at petro with shared tanks using 87-94. |
After driving for a while on a new fill of polluted 94, I see knock, add a few ounces, try again if IAM doesn't move to 1. Usually the first few ounces of Torco in petrocan 94 does it.(Still available I believe from BRZWORLD). Don't know about Boostane. :) |
Hello all - I've been researching RaceGas (Octane boosters) for Supercharged twins and the results are actually impressive. With Boost + 94 Octane + 32 ounzes of RaceGas in your gas tank you'll achieve about 40-50 extra WHP.
My questions is if an individual is thinking of buying RaceGas, a can of 32oz seems quite expensive. Does anyone know where you can find RaceGas by the barrel or drum in Ontario, particularly the GTA? |
Just want to give you guys an update.
I am now using Shell 91 with boostane professional (1 can). It works really well, IAM is at 1 and no more knock on my supercharged BRZ. For some odd reason, it is actually better than Chevron 94 + Boostane (per datalog). Chevron 94 has a few small correction. No idea why. |
I'd like to add a couple of things. To give some perspective, while I am new to the FT86 platform, I am far from new to tuning and much of it has been high performance high boost 4 cylinder engines of Japanese origin.
To the BC person who is using Chevron on their boosted engine, switch to Shell 91 Vpower Nitro+ Has to be the Nitro+ one. For a few years now, many of us out in BC with boosted tuned cars have noticed less timing being pulled, less knocksums etc with this fuel. Replicated at will over years on many different platforms. Datalogs and live data to back it up, not just butt dynos. And secondly, in no way is water/methanol injection dangerous or "bad" for the engine in and of itself. If you don't stay on top of it, and run out of juice, you can damage the engine if you still romp on it because now it will knock like crazy. I have run a 3 nozzle methanol water injection system for over a decade on a daily driver and on a weekend warrior with zero problems except for a small leak and running out of fluid a couple of times. Both are no problem if you are paying attention. Hell the leak even happened on the dyno. We just noted it and kept going, monitoring knock and timing of course and keeping the tank full. Have a reliable way to monitor knock. Live if possible. I had converted the cars stock boost gauge into a knocksum gauge so it was a dead giveaway if something was wrong. Don't be scared of a good methanol/water injection setup. It also cleans valves and piston tops and keeps cats healthy. My emissions testing numbers were always extremely good. many 0.00 results. If I can find a small enough pump, I will probably do it on my BRZ as well. E85 isn't available to my area and I don't like the lower energy content of alcohol for a daily driver either. Knowing how octane dependent these engine are, I suspect E85 type gains could be had with a simple methanol/water injection system. |
Not exactly GTA, but they will make you almost anything you want... bring wallet :) |
| All times are GMT -4. The time now is 09:23 AM. |
User Alert System provided by
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
