You may have a couple of unrelated issues going on so it would not be your starter noise. |
Just stopped by the shop and we tried turning it over, sounds like the starters just not engaging. I'm betting when it's cracked open something got damaged in there and thats what I heard break off. |
Sounds like a loose/damaged flex plate. Probably took out some other stuff after being driven that way for so long. :(
That first video with the sound under acceleration is a real tell. Something's getting tweaked out of line and colliding with the block or bell housing. |
:D humfrz |
2 Attachment(s)
https://youtu.be/OMXnsQXdop0 video of the rattling from inside of the car after a cold start. The rattle is occuring anytime I move it out of park, but also happens on first start up. https://www.ft86club.com/forums/show...73#post3208473 I wish I knew what actually happened in this situation, because it sounds like the same exact thing as mine. Quote:
Unfortunately set pins doesn't mean much to me. |
Flexplate cracked again, thinks I could have a bad transmission, or unbalanced crank. Also it was noticed that dowel pins were missing. From what I can tell from my limited google-ese, they're to align the tranny to the motor, I would imagine they would also limit the play going on. |
F |
They fall out all the time. It's a thing. |
Yeah it's a toss up wether they stick to the engine or trans when you separate both. Whenever I replace an engine or trans for a used unit, there can be two, one or none at all, and yeah it's pretty important to have them in.
I'm surprised a mechanic would forget them since they make mating the engine to the trans way easier by lining everything up. You align those and the two big puzzle pieces just snap together and every bolt hole lines up perfect. Would be a pain without those. Btw, I'm not sure if I'd be confident in that engine anymore, if the transmission was misaligned enough to break the flex plate, it probably put a lot of stress on the rear most crank bearing especially during startup with no lubrication. I wouldn't be surprised if the rear main was scored from having the crank wedged off axis. |
| All times are GMT -4. The time now is 11:35 AM. |
User Alert System provided by
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
