-   Software Tuning (https://www.ft86club.com/forums/forumdisplay.php?f=88)
-   -   Unplugged ECU with battery hooked up seems Bricked (https://www.ft86club.com/forums/showthread.php?t=136969)
solidsnake11 09-22-2019 01:12 PM
I was being lazy and did not unhook battery. Then unplugged ecu and reconnected it. It will not start or respond to tactrix or elm. I have the 2017 limited cluster and it says engine coolant high tempature. This is a 2013 brz smart entry. Anybody have any advice? I have already ordered two used ecus.
Jaden 09-22-2019 05:08 PM
It may be bricked...
Not exactly the same but I had a problem with laptop dying during a write and mine seemed bricked. What I had to do was disconnect the battery and press the break to fully discharge everything and then reconnect the battery and I was able to connect to and rewrite it.
I would try disconnecting the battery with the ECU plugged in and pressing the brake for 30-60 seconds and then reconnect the battery and try to connect with tactrix then and see if that works for you.
Jaden
steve99 09-22-2019 07:04 PM
As above with everything plugged in remove battery , press brake, try tactrix again after reconnecting.
Stil no go diconnect battery for 30 minutes try again.
Id be quite supprised if ecu is damaged unless you shorted something. Ix say either ghe ecu or other modules in car are in a strange state when they lost contact with ecu
solidsnake11 09-22-2019 07:14 PM
Thanks guys, I wish we had an open source recovery. I would give a donation for that. One more question do I wait in till the bell gets through dinging before I hit program.
steve99 09-22-2019 07:16 PM
Originally Posted by solidsnake11 (Post 3260039)
Thanks guys, I wish we had an open source recovery. I would give some moneys for that. One more question do I wait in till the bell gets through dinging.
Tactrix you always need to turn ignition on full, not accessory, engine stopped. Then wait 15 seconds, before trying read or write
steve99 09-22-2019 07:17 PM
Did you write to ecu just prior to unplugging ecu ??
steve99 09-22-2019 07:19 PM
Make sure all 4 ecu plugs are pushed in all the way till the clip clicks
solidsnake11 09-22-2019 07:21 PM
No just unplugged it.
solidsnake11 09-22-2019 07:22 PM
Will do.
solidsnake11 09-22-2019 07:27 PM
Going to try again. Will post results later. Thanks again!
solidsnake11 09-22-2019 07:49 PM
Obd2 communication failed trying oem bootloader....
Oem bootloader communication failed.
This is what I get.
steve99 09-22-2019 08:01 PM
This is what I get.
Does it read vin number and calid ??
Have you ever flashed this ecu before with tactrix ?
Os battery volts near 12v
solidsnake11 09-22-2019 08:09 PM
No vin or calid.
12.3 volts
I have flashed it about 30 times or more.
Techstream doesn't communicate nor my elm.
solidsnake11 09-22-2019 08:30 PM
Before it was bricked the cluster would say the same thing "engine coolant high tempature" when I was loading a rom. Now it's permanent anytime the key is on.
