-   Suspension | Chassis | Brakes -- Sponsored by 949 Racing (https://www.ft86club.com/forums/forumdisplay.php?f=59)
-   -   Dust in engine bay? (https://www.ft86club.com/forums/showthread.php?t=136892)
m86 09-17-2019 11:14 PM
Dust in engine bay?
I noticed that my engine bay is covered with dust / dirt. I don't remember it being like that a few months ago.
Since I recently installed camber plates (replacing top hats, so it's open to the wheel well), I'm thinking that dust is coming in through it?
If this makes any sense, what would be the easiest way to cover it?
8RZ 09-18-2019 09:08 AM
Clean your engine bay more often.
Muskoka800 09-18-2019 11:01 AM
My engine bay was spotless until one trip down a 1 kl gravel cottage road. Now it has a thin film of white dust.
Shampoo time.
DarkPira7e 09-18-2019 12:54 PM
Get about 15 cans of expanding foam sealant, and a stack of Roxul fireproof soun deadening insulation. You'll be able to seal the engine bay completely! No air coming in that isn't filtered by the radiator! You could always block the front with cardboard or sheet metal for an air tight seal.
Capt Spaulding 09-19-2019 06:41 PM
Create your own Chernobyl right there under the hood. :confused0068:
norcalpb 09-19-2019 06:50 PM
Which camber plates? If it has a round opening you may be able to buy an exact size plug.
But this is one of the reasons I switched from camber plates to angled top hats with dust covers. A daily driven car, IMO, should not have exposed bearings like that.
ls1ac 09-19-2019 10:41 PM
Only drive in the rain-----no dust
86MLR 09-19-2019 11:01 PM
Fixed
m86 09-20-2019 12:02 AM
Never cleaned an engine bay and don't really want to start now, that's why I'm trying to understand if the problem are the camber plates (Velox, by the way) that are open to the wheel.
I've had a car that lost the engine bay's under panel and ended up having a couple of problems when dirt got onto the belts.
But yeah, probably worrying too much, I'll just see if it starts getting a lot worse quickly.
Mr.ac 09-20-2019 12:22 AM
Oh my god! Are you ok? Do you need my grief counselor to talk to?
How dare these fly by night companies make horrible products that let dirt in. You should clap back at them on twitter. Demand some one be fired for such faulty products.
You can barrow my emotional support dog if need be.
Joking aside, your car is fucked. Don't bother even trying to fix it.
Just drive it to any junk yard and have it crushed. If you keep driving with a dirty engine it would only be a matter of time before the whole engine brakes.
I would recommend you a Honda Civic SI, but alas it's too much car for you. I really wish I could help.
humfrz 09-20-2019 12:59 AM
YIKES! Tough crowd, right m86? - ;)
I went out to my car to take a look see and I've captured a picture of what I think you installed on your car.
If you feel that the dust is entering the engine bay through those open camber plate things, I suggest you make a cap for them and glue/tape/screw them on.
It looks like a lid off a old wide mouth one gallon Mason jar might work. OK, so you don't have any of those laying around - :iono:
Maybe swipe a piece of Tupperware out of your mother's/wife's kitchen cabinet?
Roam around a store till you a lid that would fit? Plastic cereal bowl?
Bubba says just to lay strips of duck tape over the openings (that man has no class) - :rolleyes:
humfrz
Tristor 09-20-2019 12:03 PM
The answer to your question is that yes, solid spherical mounts, like camber plates, will allow dust in past the mount because they don't have the rubber topper which acts like a gasket that the OEM mounts do. I don't care about the engine bay getting dirty, but what is annoying is dust getting into my interior from the trunk area because my interior is partially stripped.
I solved this problem by putting 4 pieces of duct take together and taping around each mount. I only need to access these bolts if I'm removing the struts, which I'm not doing anytime soon, and it basically solved the problem and my interior has stayed significantly cleaner. I've never cleaned my engine bay, and I didn't bother there, but I'm sure the same thing would work.
So, in short, your answer is use some duct tape to cover over the top of the strut tower.
m86 09-20-2019 12:25 PM
Good info, thanks!
So I take it there is nothing to worry about. If it gets worse I might still try taping it since it's easy and it's not like I'm changing camber every day.
Tcoat 09-20-2019 01:19 PM
My engine bay is so dirty that many here would wake up screaming in the night at a brief glimpse of it. It is not air tight and even if a minute amount more comes in through the top hats it would be meaningless in the grand scheme of things.
