SakeBomb Garage: WILWOOD TRACK-DAY BRAKE SYSTEM
Introducing the NEW SakeBomb Garage Wilwood Track Day Kit for the BRZ/FT86!
Building on the success of our similar brake kits for our SCCA and NASA winning S2000 and RX7's. We produced this brake kit with the intention of bring race engineering to the broader motorsports market with an affordable but potent brake solution. We call this our endurance Track-Day brake kit! We have designed an affordable, light weight, and heavy duty brake system, which has great thermal capacity with extremely thick (20mm) pads, making it both a great thermal barrier between the caliper and rotor (preventing boiling fluid) while also giving a great value with so much pad to go through vs the other options out there. A true racing caliper, directional curved vanes in an affordable package with wide pad selection make this BBK a no brainier on the track or street! https://cdn1.bigcommerce.com/server5...0.1280.jpg?c=2 Our new Wilwood Track-Day Brake System, for the BRZ is available with introductory pricing for a limited time! We have put together a competition inspired brake system, utilizing lightweight, high-efficiency components. We're sure you'll agree this "Light-Track" BBK a fantastic option for high performance braking, at fantastic price points. Ultra-lightweight Forged Wilwood Calipers with stainless steel pistons and high temp seals, paired with your choice of our light-track two-piece SBG 325x32mm Premium Rotors (32 directional curved vane) This kit utilizes the same quick-change 20mm thick pads as our AP Racing Competition Kit, and the same rotor size, providing you with amazing bang for buck. The benefits of the Wilwood caliper are quite clear, with almost 3lbs of unsprung weight saved at each caliper when compared to other big brake kits, while still retaining excellent caliper stiffness. Put mass into what matters... the rotor, not the caliper This is the perfect package for customers looking for the maximum bang for their buck when it comes to braking performance. These brake calipers utilize one of the most common racing pad shapes, and accommodate a full 20mm thick pad. Not only does this provide additional thermal insulation for the calipers, but with a massive 50mm of useable anulus, wear on the face of the rotors, as well as the pads, is greatly reduced compared to smaller profile brake kits. This results in much more robust lifespan for both the rotors and brake pads, and maximizes your dollar per braking compound/use. Our Package Includes: Wilwood Forged Superlight Calipers (hard anodized or powdercoat options available) SBG 6061 Billet Caliper Mounting Brackets SBG 325x32mm Solid Mount Premium Brake Rotors [B] *]SBG Designed Race Grade Aluminum Rotor Hats SBG DOT Approved Stainless Steel Brake Lines with dirt/abrasion sleeves Full Pictorial Installation Guide This kit has everything you need to overhaul your aging, undersized stock brake system. From stock cars to high horsepower builds, this brake setup is a fantastic match with outstanding braking performance that will not break the bank. Wilwood Forged Superlight Calipers: Ultra-Lightweight Forged Aluminum Construction Durable Hard Anodized Finish (optional powdercoat available) Stainless Steel 4 Piston Design 20mm Thick Brake Pad for Caliper Heat Transfer Thick Pads Provide Extremely Long Life and Reduce Frequency of Replacement (cost effective for track use) DOT Rated SakeBomb Stainless Lines included! SBG Brake Rotor Features: Endurance Sized 325mm x 32mm High-Performance Rotor Light-Weight 2-piece Brake Hats SBG Rotors feature 32 Directional Curved Vanes Proprietary High Temperature Alloy Rings SBG Slot Pattern engineered to increase pad bite, Race Grade Hard Anodized Aluminum Rotor Hats See Product page for more details! Click here. SakeBomb Garage |
In to see how long it takes a moderator to close this...
| All times are GMT -4. The time now is 06:49 PM. |
User Alert System provided by
