-   -   Valenti Tailight Rewiring (https://www.ft86club.com/forums/showthread.php?t=135638)
coconutboy 07-07-2019 02:08 PM
Ok so long story short I hate the way my indicators look on my Valenti taillights.
My guy accidentally ordered the JDM ones, so my brake lights were yellow (triggered the indicator) and my indicator was flashing red (triggering night time lights)
Does anyone know if it's possible to wire the indicator (yellow) to the outer light (red)?
This was actually the case out of the box, but the fuse only looks like it can fit one wire.
There are 4 fuses in total.
I think you can do something called soldering? Not to familiar with that though, and if it will even work.
Thanks
https://uploads.tapatalk-cdn.com/201...5fddb8a698.jpghttps://uploads.tapatalk-cdn.com/201...24b55b0137.jpg
Sent from my SM-G950W using Tapatalk
JD001 07-07-2019 02:16 PM
I think you've got your wires crossed.. the query is appearing as 3 separate posts..
coconutboy 07-07-2019 02:20 PM
Yeah i tried uploading on wifi a few times didnt work. Turned my data on, and they all uploaded. Cant even delete them on the latest update for the Tapatalk app -.- but yo if I dont think I can rewire it, because one wire perfectly fits into the fuse. There is no way two of them will fit
coconutboy 07-07-2019 02:27 PM
This is what it looks like https://uploads.tapatalk-cdn.com/201...c2a00b6784.jpg
Impureclient 07-07-2019 03:04 PM
https://www.ft86club.com/forums/forumdisplay.php?f=36
There's also a subforum for this. Posting in general when there is a specific place in here for the specific question you asked won't help you as well.
soundman98 07-07-2019 03:05 PM
You need to repin the harness.
My phone is acting up, search youtube for repinning frs tail lights
coconutboy 07-07-2019 03:16 PM
I actually did repin the harness because they were wired backward when I got it. I want two cables in one input
humfrz 07-07-2019 03:24 PM
Well then, just "piggy back" the wire coming out of the one inlet/outlet - ;)
humfrz
coconutboy 07-07-2019 03:26 PM
humfrz
Will it work? Just nervous I'll fuck it up LOL
humfrz 07-07-2019 03:36 PM
Just strip a section of insulation from the wire coming out of the plug, then wrap the other wire around it. Then tape the splice up with electrical tape.
Will it work? :iono: I have no idea of what you're trying to do?
humfrz
JD001 07-07-2019 03:44 PM
humfrz
I think the OP is trying to get the amber light to behave like the red light and the red light to behave like the amber light.
If I was in his shoes I would ensure that my shoes had a think rubber sole and I would exchange the JDM lights for what works in your country..
soundman98 07-07-2019 03:49 PM
Not possible without a lot of extra work involving blocking diodes and extra wiring. Not something i would recommend for someone not sure what soldering is.
coconutboy 07-07-2019 03:56 PM
Just to clarify I wanted my lights to do the following
Night time lights: red outline on lights
Indicator: red outline on lights that would flash as an indicator
Brake lights: OEM
coconutboy 07-07-2019 03:59 PM
You may be right. It just looks tacky to me tbh. I think I'll either have to ask a specialist and show it to them in person or get someone to do it for me. Just wanted to know if someone has done it before
