-   -   R2RO's Varis 86S (https://www.ft86club.com/forums/showthread.php?t=13357)
R2RO 10-06-2015 01:01 AM
Originally Posted by midnight23 (Post 2411316)
saw it today while I was at Evasive, love that lip kit!
Thanks man! Love your build also! My cars been there for along time, almost 3 months tomorrow. I got unlucky and got one of those faulty DW Fuel pumps, took awhile for the guys over there at that shop to figure out what was wrong with my car. Hopefully I can finally take her home this month.
AznKirby 10-13-2015 01:09 AM
Jesus those seats.
R2RO 10-13-2015 09:51 PM
Originally Posted by AznKirby (Post 2418287)
Jesus those seats.
I highly recommend them, they're so comfortable and keep you in place when taking corners very well :party0030:
R2RO 12-03-2015 12:40 AM
Most recent photo of my car in its current state, running the Volk Racing RE30's CSII.
ottoyu34 12-03-2015 01:11 AM
Sick build. +1 on Quality parts.
pleong 01-14-2016 01:14 PM
did you ever get the design craft clutch fork?
outlaweking 03-12-2016 08:44 PM
Did you have to roll the fender for the Advan?
R2RO 03-29-2016 08:57 AM
No I didn't, I was trying to reach him for months but no response back. But I had Evasive motorsports reinforce a spare stock one for me, Since my clutch starting making a really loud sound on deceleration it was only noticeable at low speeds(sub 30mph/4000rpm). The clutch still worked 100% and made no noise on acceleration. The clutch was reinstalled with the custom fork and I haven't had a problem since, also my stock fork was noticeably bent compared to the custom fab'd one. Just a heads up since I know you run a Twin plate also, its worth upgrading if any problems that I stated pop up on you.
Here's some photos of my stock fork and the custom one(Not finished at the time). It was fully reinforced when it was reinstalled, I just don't have photos of it finished.
http://www.import-addicts.com/home/w...2-16.36.03.jpg
http://www.import-addicts.com/home/w...2-16.36.58.jpg
R2RO 03-29-2016 09:01 AM
No fender work, but some adjustment was made with the alignment to make sure everything worked. But the car still rubs on full lock with 255 width tires with what I believe is a 1.9-2.1 inch drop, Im not 100% sure on the height since we have raised and lowered it multiple times.
pleong 03-30-2016 08:20 AM
I was thinking of doing the same thing too... I reached out to him some more this past week.. I guess if it comes down to it, I'll just have to do the same.
R2RO 04-06-2016 10:56 PM
Finally dropped off the FR-S at Outfront Motorsports for the full rebuild on the FA20, Its going to be the 6th I believe Closed deck FA20 in the world. Since I have yet to see another company begin to develop a closed deck system for the FA20, I can't wait for this thing to be done and become one really high hp FA build! Stay tuned for the specs and updates as I get them from Outfront over the next month and weeks ahead!!
Specs:
-Closed Deck Service
-Bore/Power Hone w/ Torque Plates
-CP Custom High-Compression Forged Pistons w/ceramic coating
-Carrillo Pro-H 3/8 CARR Bolt Connecting Rods
-Kings Performance Rod Bearings
-Kings Performance Main Bearings
-Outfront Motorsports 1/2" Stud kit
-Stage 2 Porting for heads
-Supertech Stainless Intake Valves
-Supertech Inconel Exhaust Valves
-Supertech Dual Valve Spring kit W/Titanium Retainers 74 lb
-WPC treated (New FA20 Crank, Main bearings, Wrist pins, rockers, Cams, Rod bearings, and piston skirts), fully balanced and blueprinted.
-Genuine Subaru Gasket Set
-FLUIDAMPR Engine Damper
http://www.import-addicts.com/home/w...9994026144.jpg
http://www.import-addicts.com/home/w...9994062105.jpg
Closed deck goodness from outfront motorsports!
http://www.import-addicts.com/home/w...9994159856.jpg
http://www.import-addicts.com/home/w...9994214477.jpg
http://www.import-addicts.com/home/w...9994188364.jpg
wnt3d 06-28-2016 09:37 AM
Specs:
very sexy looking built motor you have chosen. You've re-lit my desire to build the FA20 instead of doing a motor swap. Are you staying with the same turbo after the built motor arrives? keen to see results on a closed deck fa20
R2RO 06-28-2016 07:40 PM
Once we sort out the motor (Its having a few problems from reusing the old VVT cams from the blown motor). We're gonna first max out the Garrett GTX2867R which should run out of steam around 20 PSI and should be around 400+HP on E85.
Next comes either the option of a direct bolt on Garrett GTX3076R, which we will try to get it too mid 600 HP numbers on E85 or might just switch it up and go with a new twin scroll manifold fro, JDL and put a BorgWarner turbo on it. Or we might try and stick on a Garrett GTX3582R and try and hit 700Hp haha :D
Personally I don't look to run more then 700Hp on the block, because I don't want to put that much strain on the Carrillo rods since they personally might be the weakest point in the whole build. Not because of the company, but because these FA motors run a offset design rod that isn't as strong as a straight one.
If you go this route you should try and bore out the motor to 2.1 or 2.2L since the closed deck reinforces the block in the most vital area when the piston is fully compressing the gasses. Either route you go i'm pretty sure you will enjoy this motor, you will be able to beat on it all day at 500-600HP numbers and not have to worry about reliability.
R2RO 07-04-2016 02:11 AM
Finished installing my AP Racing Endurance kit on my FR-S today, Im going to do a full review and write up on my website Import-addicts.com Its going to have really high quality photos and tasteful review. So far I love these brakes it was a piece of cake to install if you refer to the instructions step by step, thanks Essex for producing these high quality brakes!
Here is the fitment with both of my wheel sets the Street (Advan GT) and Track (Volk RE30), Enjoy!
Advan GT 18x9.5 +40 (So much clearance! 1.2+in)
http://www.import-addicts.com/home/w...07/fffttt1.jpg
Volk Racing RE30CS2 18x9.5 +40 (About 0.5-0.7in of clearance!)
http://www.import-addicts.com/home/w...07/fffttt2.jpg
http://www.import-addicts.com/home/w...07/fftttt3.jpg
