-   AUSTRALIA (https://www.ft86club.com/forums/forumdisplay.php?f=20)
-   -   Engine oil - what should we (Aussie) use? (https://www.ft86club.com/forums/showthread.php?t=13352)
m.wood0213 06-23-2013 06:28 PM
i accidentally put 0w-30 in my brz the other day and it seems fine
Blue86 06-25-2013 10:59 AM
Just had 5W30 best LiquiMoly put in along with LiquiMoly diff and manual gearbox oils too. So much smoother! Car sounded like a tractor before.
000 Racing 06-26-2013 03:16 AM
No issues from Royal Purple 5w 30 racing. I have changed the oil for each round which is around 3 hours of running time 5500 to 7600 rpm. I do think if you track your car from time to time then 5w 30 is the go, if not then the rec 0w 20 is fine.
I would suggest if you love your car then get a 7500k oil and filter done between the book service. If you do that then no probs.. it would be a bugger in two years to find long services = broken cams or spun bearings like some big k services have produced.
I also think if you change your oil every 7.5k then the argument is hypothetical ??
CR
Hags86 07-09-2013 10:45 PM
So I've read this thread and many others and the "101" series on Bob is the Oil Guy.
From what I can read "other than it depends" is that for this particular car:
1. Normal daily / spirited driving = any fully synthentic 0w-20 oil will do
2. For track use ideally you monitor oil pressure and pick one that gives approx 10 psi for every 1,000 rpms.
Has anyone actually done point 2 and got an oil pressure reading with 0w-20 or any other oil for a car being flogged?
ZZT86 07-09-2013 11:22 PM
Maybe Chris from 000Racing has some data for you . . . .
450hp/tonne 07-15-2013 10:47 AM
Manufacturer preference:
http://i1139.photobucket.com/albums/...472FAD6F5E.jpg
gcmak 07-06-2020 12:39 PM
Originally Posted by 450hp/tonne (Post 1070065)
sorry for reviving an old thread.
my 2020 brz manual seems changed - and checking parts sites online it seems like 2017+ vehicles have a different set of optional oil weights. i'm not sure what the reason is behind removing 5w-30 and 5w-40 as optional for the vehicle and sticking to 0w-20 (5w-20).
https://i.imgur.com/F6pWoeZ.jpg
thoughts?
