| RACECAR go brrr! |
09-23-2022 09:43 PM |
Originally Posted by Swolzee
(Post 3548704)
Has anyone had inconsistent power when using the 12 volt source from the track box harness?
I'm just now piecing my car back together but I tied in my four Halo ring switches and my Greddy gauges all on the 12 volt source coming from the track box. Currently my gauges will turn on with the ignition switch and then turn off once the car is cranked or just after they've been on a few seconds, and the halo rings are illuminated but pulse bright to dim.
I'm going to dig a little deeper tonight or tomorrow but I figured I would ask the question to eliminate as much as possible.
Yeah, that is too much going through that TracBox. It's really only meant to provide enough power to allow switches to act as signal wires, and power the switch LEDs.
I reached out to Gerald to ask his thoughts and he said, "The internal resettable fuse it set to 150mA. Enough for all the LEDs. And the tracbox itself. You should never use it to power anything else."
