If you don't go to the track I would bleed the brakes yearly, at a minimum, while your there pull off the calipers and clean them well with brake clean, check your seals, check your pistons and throw on a little anti seize on the pins If you travel on wet or dirty roads pull your pads and clean, service your calipers more often. I tend to be pretty thorough when it comes to servicing and maintaining my brakes. A little maintenance doesn't take long and it will keep your stoppers in peak condition. |
Not to be nitpicky, but you'd be better off using grease rather than anti seize. Anti seize is a great high temp lube, but a terrible high pressure lube. It squeezes out when two surfaces come together, unlike grease which leaves a film. |
GUY!!!! CAN WE PLEASE GO BACK OFF TOPIC??!!??!
YOU'RE RUINING THE THREAD!!!!! |
Forgive my ignorance....... |
Now is the time when we dance on Sprockets. https://i.gifer.com/Chty.gif |
Other members have put in some valid and good responses, others, not so much. Not everyone in an expert or component in these matters, hell, I'm no expert, but, I've learned alot from experience and browsing forums. The problem is when a post gets derailed before the OP's question has been answered it becomes just another useless thread without any real benifit. Apart from bored people with nothing better to do than derail a thread without actually attempting to answer a question. I feel sorry for some members when they post a question, which, in their mind is valid, and it gets derailed by bored people. Sure there are questions which seem strange, but, if the replies are IRT to the question maybe the OP can learn something. But carry on as you were, don't supply any relevant information, and continue to turn a post which could have some relevant information into another wasteland thread of post counts. On topic: OP, valid question, no you cannot really tell pad thickness at the pedal, but, you can diagnose issues like bad fluid, siezed or poorly functioning calipers, warped discs. If you want to check your pads pull the wheels and have a look, while your there check for cracks, thickness and wear IRT your discs. There is a plethora of information IRT brakes, you just need to sort through the crap, brakes shoud be right up there with your periodical maintenance, get to know them well. |
Anti-seize is NOT a lubricant. (well, not primarily) It is an anti-corrosive. If it was good for the guide pins then the manufacturer would use it there. Stick with the manufacturer's recommendation. Three different compounds are specified for the caliper. https://demos.starbase7.net/t3Portal...00CIF02EX.html |
I've been using silver anti-seize for 30 years on the backing plates and pins . I've never had a issue using anti-seize, street cars, track cars, bikes, but, that is along time to be doing it wrong. More research is needed on my part, I'll do some googles on the OEM Brembo's and find out what I'm meant to be using on them. Cheers |
The nickel stuff stands out because it's quite toxic. |
| All times are GMT -4. The time now is 03:11 PM. |
User Alert System provided by
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
