| churchx |
08-24-2018 06:02 AM |
I just topped up till max level in tank again, which shut off parking brake light, and drove pads (almost) till end of them (of course, one will need to remove some excess fluid, after one changes pads to new ones, of full thickness).
But still, i wouldn't "rely" on this indicator to tell pad wear. Better check their state/wear properly (alongside other things/systems of car/their state & wear to inspect) at very least prior trackday. It's helpful if you keep some notes (eg. installed pads of type # at ##.##.#### date, drove # hours/days at # track).
And alongside extra tires, some oil bottle, drinks, basic toolset, air pressure gauge & pump, take to the track also hydraulic jack, needed wrenches, extra pad set, fluid bottle, if you wear down current ones too fast (or find out if you will be able to get them changed on site, if needed). Brake subsystem is about the most important in any car. Especially if it is abused at track loads.
As all pads are compromise of sort, so many change to track pads prior track day, and to street ones - after, to have best for purpose every time, instead of dealing of shortcomings of universal/hybrid pads. Pad change is good chance to inspect their state too (and to add extra notes during change on how much pads material in mm you wear down of specific pads on specific tracks on specific tires or car setup and for how long). Also you can note what fluid and when you flushed. And if/after what you boiled it up :).
