https://www.amazon.com/Sunway-Solar-.../dp/B01MYVUSRH https://www.amazon.com/Battery-Tende.../dp/B004Q83TGO https://www.survivalrenewableenergy....-charger-kits/ |
My 51R battery is still chugging away. |
I ended up getting a Deka ETX15L. I'd used a Braille 14115 previously.
I 3D printed a spacer to center/hold it within the stock battery tray and raise it up just a little so I could use the stock tie-down. Also 3D printed a block to fit around the curved part of the stock hold down and to spread the load out over a wider area. Seems to work well - I'd done something similar with the Braille and it held up through 2 HPDE seasons and was going fine when I traded the car. The deka was way cheaper than the braille. $80 all in with the terminal adapters. Deka 11.8 lbs with mounting hardware. https://www.ft86club.com/forums/pict...ictureid=12403 Stock 33.95 lbs with mounting hardware. https://www.ft86club.com/forums/pict...ictureid=12402 More on the 3D parts here : https://www.ft86club.com/forums/show...&postcount=123 |
Until, I forgot my oft plugged in for 5 days. The charger became recalcitrant swapping into charge mode , after 24 hrs. the charger would still not go into charge mode, but it eventually went into store mode. Will report on reliability, after a long one of these - :burnrubber: |
Originally Posted by RFB View Post Mini Shorai - First 2 years of winter use up to 3 days parked and the car would start, but at arctic temps it was on a tender. Now I prefer a normal battery in the winter for peace of mind. Sixth year tracking and D/D, Shorai 5 lb. battery still going strong ! Quote:
Just got this for my track car, and I have been running the same format Lead/acid battery with less CCA for almost 2 years now.
https://antigravitybatteries.com/wp-...um-battery.jpg YTX12 case size 5.9 x 3.43 x 5.12 inches (LxWxH) 360 Cranking Amps 12 Amp Hours (Pb Eq) 3 lbs https://antigravitybatteries.com/pro...size/ytx12-12/ |
another year
As is the built block and supercharger, :D amazing! :confused0068: |
| All times are GMT -4. The time now is 04:44 PM. |
User Alert System provided by
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
