-   -   How reliable are OEM radiators with plastic end tanks? Has yours failed? (https://www.ft86club.com/forums/showthread.php?t=129375)
Sapphireho 08-09-2018 01:19 AM
Originally Posted by Irace86.2.0 (Post 3119583)
Actually it was three times the value, but at the time a running car is a running car.
So so true! Awesome.
FRSBRZGT86FAN 08-10-2018 02:56 AM
I think this is more to do with the year and era of when these plastic end tanks were made, these modern cars have better manufacturing processes and quality control on those plastic parts than the plastic parts of old.
I know e36s m3s and other bmws from the 90s-00s had major issues with the plastic end-tanks cracking. On our cars however it isn't an issue.
FRSBRZGT86FAN 08-10-2018 03:00 AM
Originally Posted by finch1750 (Post 3118908)
147k miles here and radiator is fine. I do have coolant evaporation when driven hard but it's done that since I first got it essentially
I have that "issue" but it's more prevalent during the summer, and I've had a gallon of subaru oem coolant in my garage since 2016 that I used to top off the system and it's not even close to empty. It doesn't really lose alot of fluid, almost a 1/4-1/2 an inch of fluid in our 5 month hot summer period.
Apparently someone said the fix is that there's evaporation occurring through the OEM hoses and through the top cap of the expansion tank. So putting tape over the expansion tank cap and swapping the hoses to aftermarket with hose clamps seems to do better. But it's honestly a non issue for me as it isn't a crazy loss.
finch1750 08-10-2018 03:11 AM
By the time I did my coolant change I had used almost a whole gallon of coolant to refill the overflow. I think this time around I'm just going to use water to top it off.
mkodama 08-10-2018 03:22 AM
BMWs have been running 2.0bar/29psi cooking systems since the 90’s with plastic radiator end caps, and they rarely, if ever, failed. The pressurized coolant reservoirs aka expansion tanks (with much greater effective diameter and hoop stresses) were a whole different story.
