Stock brz ride height
I installed coilovers over the weekend and I forgot to measure the wheel center to fender :bonk:
I've searched and only found fender to ground measurement. Can someone help me out. Thanks |
I believe it's 14.5" from hub center to fender in the front. Not sure about the rear, but it's probably about the same.
LOL, I did this with my Honda accord daily a month ago. Good luck to me finding the measurements, at least here we have enthusiasts!
OE Tire size is 24.6" diameter
Take the fender measurements you found and -12.3" for the measurement you want. |
Thanks fellas
Took from https://www.ft86club.com/forums/showthread.php?t=8739
Need to determine how much your car has lowered? Distance between hub center and top of fender opening Front is 14 7/16" and rear is 14 5/8" |
As per the shop manual:
Front wheel arch to wheel center: 375mm (14.76") Rear wheel arch to wheel center: 372mm (14.65") |
| All times are GMT -4. The time now is 02:04 AM. |
User Alert System provided by
