http://stmedia.stimg.co/CTYP_News_Sk...Utne.jpg?w=800 |
Steel wheels, unpainted bumpers, cheaper interior, no exhaust tips, etc. The dash trim is straight up missing 🤣” so again... I was just translating the numbers from that post, I didn’t “tell” you anything. Good luck with getting a fugly stripped down twin to save a few grand though... |
And about the 6% accleration increase, it was related to a lightweight flywheel and not a pulley. You are suposed to work for years in the automotive industry and you should know better. The factory flywheel is designed to be heavy for storing kinetic energy and absorb vibrations in low speeds. If your car is not a daily driver and you don't drive much in town, then you can go for a lighter one without any compromises. |
Why couldn't you have a two door and a four door that had the same rear sub frame, suspension and drive components. Front sub frame, suspension and steering components. Same transmission, same engine? If the main component attachment points are of similar dimensions, the cars become Lego's. The term "platform" is kind of a broad term. |
Yes, but this has been done by Subaru for decades. For example you could swap without issue components between a Forester and a WRX STI and in fact the factory has done this quite often in their limited editions. It is not something really new. If what they realy mean now as a "global" platform is to have for example a single CVT and place it in all the models , when in the past you had a 5-MT, a 6-MT, a 4-AT, a 5-AT and a CVT then I don't really see it as a progress. It is as you said trying to play Lego, but now with fewer pieces and much less diversity. |
The only real thing I can see is the statement that Subaru’s two plants in Japan and the one plant in the U.S. will be able to build all their vehicles on one assembly line. Anything else is not really related with the "global" platform and it is more relevant with the next generation platform. What I can see by doing this is just giving more resources to the U.S. plant since this is their biggest market currently, but with the expense of less diversity. Before this, I don't believe there was any issue with the two plants in Japan. Don't compare Subaru with other automakers. They were quite small and very localised and they knew already about scale economy. |
Can we please get back on topic?
1) This is wonderful news if true. 2) I really hope they stay true to the original mission statement, and the 2nd gen doesn't suffer from bloat and focus group requests (i.e. more room! bigger rear seat! etc etc) 3) If Subaru plans to use the new corporate 2.4 liter maybe there's hope, the 2nd time around, for an NA and turbo option. Would be strange, as for a lot of people I think the extra power of the 2.4 would be enough to satisfy them, thus maybe removing some demand for a turbo model. Then again, that's the kind of backward logic we see all the time from automakers.:bonk: |
I feel like 20-30 hp via a larger naturally aspirated engine would not necessitate large changes or weight gain.
50+ hp from a turbocharged engine, and it's obligatory torque, yeah I could see "bloat" happening. |
The FA20 currently has a power ratio of 100HP per liter. With any luck, it will also mean the new chosen engine will make 240HP. Most likely no need for a turbo.
I think this talk all stemmed from VW's MQB platform, where they hyped up things like how certain dimensions are fixed for example the pedal box, while other dimensions can be adjusted as needed, and with more part sharing than ever before (meaning a defect can literally mean fucking total recall). Before the BRZ, the modern Subaru (from 1989 onwards) was mainly the Legacy platform (which bankrupted them) and later on the Impreza platform (the Forester is actually based on the Impreza), in which the latter was derived from the former. All the innovations came about on the Legacy first, then trickled down to the Impreza. You can also argue the BRZ is basically another derivative from the Impreza. I haven't read enough to understand how the Alcyone SVX was developed, probably based on the Legacy. |
@nikitopo
Okay I finally found the diagram which I saw many years ago on the web: http://www.thetruthaboutcars.com/wp-...014/08/mqb.jpg Well you can call it progress in terms of a supposedly cost savings exercise, but not progress in the traditional sense (I mean come'on let's face it; the dude at Das Auto who actually came up with this got canned soon after it was implemented lmao). |
The platform is not restricted to AWD it isn't even restricted to gas powered engines. It is designed to do everything they need it to do. If it can be used for a compact hatchback it can be used for a RWD coupe. How is this concept so hard for people to grasp? "Flexible — without all the flexing" "The Subaru Global Platform is so named because it can be adapted to the requirements for everything from a compact hatchback to a 7-seater SUV. This level of flexibility has many benefits to the Subaru customer and to the environment. Existing Subaru factories around the world can be quickly turned over to produce different models according to what types of vehicles customers want and need. In addition, this revolutionary design can be modified to accept a variety of powertrains; ranging from our current gasoline SUBARU BOXER engines to future alternate powertrains down the road. The result: a truly flexible and environmentally friendly way to meet the needs of drivers for years to come." |
It is like trying to fit everything in a single bag. Some will have to remember how the BRZ platform evoluted from the Impreza platform and achieved a better weight distribution and lower cog, because it had a specialized engine and the advantage of not using an AWD drivetrain:
http://i66.tinypic.com/11j147p.jpg http://i65.tinypic.com/ir8i91.jpg |
The image a page ago is misleading and simplified. |
Edit: Wait, I just described a Lexus RC.. |
Yes that image is very deceiving since it supports the myth that a "platform" means a prefabbed base that everything just bolts on top of. |
As long as the heritage of the car continues I will be happy. I don't foresee selling mine anyway even for a significantly updated version. |
That said, the BRZ is a joint project with Toyota and I doubt if Toyota would approve of the inherent weaknesses of the global platform for a sports car. The proportions of the global platform are all wrong for a car as low as the BRZ. If you don't have any engineering experience, have an engineer look at the picture and then tell me how they could possibly get a RWD only low car out of that platform. |
Thanks to VW and the handful of car part suppliers now every car manufacturer's marketing dept will have to sell a "global platform" regardless of what it is in reality.
If Subaru goes it alone they should do a 3rd gen Alcyone instead of a BRZ successor. http://oldconceptcars.com/wp-content...u-acx-ii-1.jpg http://www.subaru-svx.net/forum/atta...1&d=1399261004 http://i64.tinypic.com/s6kc9t.jpg |
There have been and currently are 100s of vehicles that come in AWD, 4WD, or 2WD that use the same platform there is no design criteria that excludes any setup from a platform. |
https://www.subaru-global.com/ourstory/ourfuture.html http://www.subaru.asia/mig/en/subaru...l-platform.php http://drive.subaru.com/spr16-global-platform Google is your friend.... You'll see that the basis IS a frame!!!!! |
Use your Google mastery to show us the platform for each model that they will be using it on not just one generic shot that they use to show the basic layout. If you want to play the sarcasm game I am up and ready to go so in all your ancient wisdom tell me what these radically different cars have in common. 2006 Toyota RAV4 2007 Toyota Corolla (2009- in US market) 2005 Toyota Avalon 2007 Toyota Camry 2007 Toyota Aurion 2007 Lexus ES 2007 Toyota Mark X Zio 2008 Toyota Auris/Blade 2008 Toyota Highlander 2008 Toyota Corolla Rumion/Scion xB 2009 Toyota Matrix 2009 Toyota Venza 2009 Toyota Avensis 2010 Lexus HS 2010 Lexus RX 2010 Toyota Prius 2011 Toyota Sienna 2011 Scion tC 2011 Lexus CT How about these? 2005 Mitsubishi Outlander 2007 Mitsubishi Lancer 2007 Mitsubishi Delica 2008Mitsubishi Racing Lancer 2010 Mitsubishi RVR 2007 Dodge Caliber 2007 Jeep Compass 2007 Jeep Patriot 2008 Dodge Avenger 2009 Dodge Journey / Fiat Freemont 2007 Chrysler Sebring 2011 Chrysler 200 2007 Citroën C-Crosser/Peugeot 4007 2012 Citroën C4 Aircross/Peugeot 4008 2010 Proton Inspira |
"The Subaru Global Platform is part of the six initiatives to enhance the Subaru brand described in the company’s midterm management vision, “Prominence 2020,” announced in 2014. Together with the horizontally-opposed engines, Symmetrical All-Wheel Drive (AWD), and EyeSight that represent Subaru core technologies, the new platform will constitute the basic foundation of the next generation of Subaru vehicles." The global platform INCLUDES "Symmetrical All-Wheel Drive". And it is part of the "Basic Foundation". You are just making absolutely no sense. Did you even read this? What part of "Basic Foundation" do you not understand? And did you even analyze the platform in the picture? You cannot form a sports car from that platform. Like I said, talk to someone who understands engineering and technology who can look at that platform and explain it to you. Jeeeeezzzz.... |
Next Gen BRZ/86!
Engineer here (mechanical product development), failing to see how you can't make a RWD sports car out of this:
http://www.subaru.asia/pages/subaru_...platform_1.jpg Basic structure looks very similar, biggest difference is the more pronounced triangulation in way the firewall sides tie into the fender and side rail, likely to increase torsional stiffness: http://www.circuitthreads.com/wp-con...-undressed.png Sent from my iPhone using Tapatalk |
| All times are GMT -4. The time now is 08:22 AM. |
User Alert System provided by
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
