getting only front BBK?
has anyone done this? will it be too weird to rock BBK up front and not rear?
Most reputable kits are engineered with conjunction of a oem rear calipers. The bias of most brembo, alcon, and ap racing complement the stock rear set up, depending on which kit you choose from whichever brand. If you go with the bigger 6, 8 pot kits, your chance of altering the bias increases and you will need a rear bbk, proportioning valving to balance the bias. @stlgrym3
4 POT 326mm or 355mm front Brembo or Stoptech, do those work with our stock rear brakes?
The Brembo Gt system works great with the stock rear end, this is the 4 piston 326. Rotor size will only increase weight, if you get a 355 kit with more pistons than your bias will be affected.
Stoptech st40, the 4 piston kits work as well but I forget how much forward it moves the bias. A 355 rotor would also just increase weight on a stoptech kit as the caliper stays the same. I believe Counterspace Garage offesr the Brembo Gt system and can help you with specific numbers and information to make the right decision. Ft86speedfacotry has a brembo gt kit too and stoptechs. |
yeah, i was looking at those on FT86speedfactory as well. not sure i want to pay additional 2k or so for the rear if i don't have to.
No need, just do the front. What are you doing with the car to need the BBK?
https://s19.postimg.org/p7qvq6x5v/100_1448.jpg I don't think it looks bad but it's obviously non-standard and it does poke at my OCD nerve a little that the front and rear don't match but it's a matter of function over form for me. I track 4-8 times and participate in 6-10 autocross events per year and running STI rotors and standardized brake pads means my consumables last longer and are cheaper to replace. Literally, my front BBK brake pads are cheaper than my OEM rears. Quote:
| All times are GMT -4. The time now is 09:59 AM. |
User Alert System provided by
