Would it be acceptable to have the calipers powdercoated? Would that even solve the problem?
One of our customers sent us a nice vid of him working over a large field of GT86's with our Sprint Kit. Check it out on our blog. :D
http://www.essexpartsblog.com/media/...g/MNongrid.jpg |
I ran XP10 at the track this weekend. On stock brakes and tires the backing plated turned black. On stock brakes and RE11A I turned the backing plate white.
On stock with XP10 I find the pedal is very firm and easy to use. On the AP sprint kit I find the initial bite to be non existent. The first bit of travel does nothing IMO. I got used to it thought and maybe it is a good thing because you can just stand on the brakes. Since the first bit doesn't do much it doesn't unsettle the car. Also to note the XP10 pads still have orange paint so they did not get hot at all. Not sure what to conclude but I have a few thoughts. Maybe there is a little air in system, though I bled twice and it feels firm on street pads (carbotech 1521). Or overall the car and tires are not enough for this pad compound, maybe should try XP8. Or (most likely) I'm just slow and don't get enough heat into the brakes. |
Do you know how hot the brake temps were front to rear? |
I don't know the temps, I don't have any way to check. |
Just bled my brakes again for good measure based on @CSG Mike post that I should have a good initial bite. Saw 3 small air bubbles from rear caliper. Didn't see any more air come out.
Also air sprayed any excess fluid out of the bleeder nipples and wiped off calipers to see if I find any more stray brake fluid. Can't wait for this 3 day weekend at VIR to try them out some more :) |
What the consensus on brake duct blowing on the rotor 'pad area' instead of the center ?
I understand it is not optimal, but is it something that should be avoided ? Logically a large amount of air coming only on one side of the disc doesn't sound like a great idea for uniform wear. Can anybody comment on that ? I have the APR brake kit and it seems like the Essex kit will play along with the kit without problem, but considering the oversized brake may not require any ducting, I am thinking about removing it all together. anybody running the essex kit with some brake ducts ? |
Hi all this is my first post. I warped my front DBA 5000 rotor the other day at the track which got me thinking about a proper BBK upgrade, which brought me here.
Has anyone considered pairing the Essex kits with some of the GC8 WRX fixed 2 pots for the rears? These bolt on with a custom bracket. I played around with the brake bias calculator which showed that these calipers have the exact same brake torque as the stock FT86 ones. As the Essex kits are designed to not alter the bias with the OEM rears, it would seem the wrx 2 pots would work with this kit without altering factory bias. As the same rotor is used there would be no thermal advantage, but it doesn't appear as though this is needed on the FT86 rear. However, the calipers are alloy and would save a few lbs over stock, the fixed design would offer better feel, they would visually be a nice match for the front and the whole exercise would not be very expensive at all. Sent from my iPhone using Tapatalk |
I have a setup with the subaru 2 pot rears and a custom ap fronts (similar bias to stock).
They work exactly the same as they have the same 38mm piston diameter. the rear 2 pot give a bit better feel. I bought an old set and refurbished them myself with stainless steel pistons which is other advantage (less heat transfer than aluminium). They are also light but bare in mind the kns bracket is steel... |
Thanks AJC, I have already bought a second hand pair with the intend to rebuild them.
I didn't know the KNS bracket was steel, but I don't know of any other options? It should still be lighter than stock. |
My advice on rebuilding them; dont bother splitting the capiler. The bolts are f'ing tight. I stripped them out, sand blasted, painted and rebiuld with new stainless pistons, new seals, boots and hardware. I'd recommend speed bleeders too :thumbsup: |
AP Racing brake systems in development
Actually, you are correct. Had them machined and just did another track day with no issues. What size speed bleeders for the Essex kit and subie 2 pots? Sent from my iPhone using Tapatalk |
The CP8350 caliper in our Essex Sprint and Endurance Kits uses a 3/8"-24 bleed screw. |
will the AP sprint kit fit 17x8 +35 regamasters? ty
Guys...we're giving away a free set of J Hook iron disc rings later this week to one of our current Essex/AP Racing BBK customers. To enter, all you need to do is write a review of our product, and we will be drawing the name of the lucky winner Friday. Please get your review submitted if you want free spare iron!!!
Please see this thread for details on how to submit your review. Thanks! |
SB3824 3/8 X 24 1.29, (32.78) SB3824HD 3/8 X 24 1.33, (34.03) SB3824L 3/8 X 24 1.53, (38.88) so which speed bleeder to get? |
just installed my Big Brake Kit will bleed it today excited!!!!
http://i925.photobucket.com/albums/a...325_190722.jpg
http://i925.photobucket.com/albums/a...325_190716.jpg going to test these bad boys out at big willow next week :) |
Nice! I like that SBC finish!:clap: Let us know how the brakes did at Willow. |
i wonder if there is an alternative for brake pads for street use after driving on the track my ferodo DS2500 is squeeling lol http://i925.photobucket.com/albums/a...-CaliPhoto.jpg http://i925.photobucket.com/albums/a...-CaliPhoto.jpg |
Hawk HPS is quieter, but they don't feel nearly as good. |
We just finished up some great new videos on our Competition BBK's. We walk through each of the kit components and look at the shortcomings of road brakes when used on the track. Check them out below...they're worth a watch, and more to come!:cheers:
Essex Designed AP Racing Competition Brake Kits Part I [ame="https://www.youtube.com/watch?v=p8eDnkjL2V4"]Essex Designed AP Racing Competition Brake Kits: Part I - YouTube[/ame] Essex Designed AP Racing Competition Brake Kits Part II [ame="https://www.youtube.com/watch?v=iduAqKqiQXs"]Essex Designed AP Racing Competition Brake Kits: Part II - YouTube[/ame] |
Big Brake Kit commonly asked questions
[ame="https://www.youtube.com/watch?v=4QZLggq8AcY"]Know Brakes, Episode 4: Big Brake Kit FAQ - YouTube[/ame] |
How to Plan Now for Future Brake Needs
[ame="https://www.youtube.com/watch?v=kwWqFecWZPc"]Know Brakes 7: How to Plan Now for Future Brake Needs - YouTube[/ame] |
| All times are GMT -4. The time now is 01:16 PM. |
User Alert System provided by
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
