| JRitt |
03-13-2013 10:23 AM |
Originally Posted by OrbitalEllipses
(Post 788152)
So, Caliper, tell me, how are you doing today?
I'm doing well, thanks for asking!:D
My rotor temps are ~1,050-1,150F. Caliper temps with non-full metallic pads was very low. With full metallic pads (CL RC6Es) and harder braking they were in the mid-upper 300s which is pretty warm but not hot enough yet to be a concern, not enough to boil fluid, etc.
It is enough that I'm actually considering brake ducts though, just in case..
What he said!:thanks:
Most people just think of brake ducts as something to add cold air to the brake system. They are actually more of a tool in managing heat in the brake system, as you don't always want more cool air. On some tracks, one would want to have your ducts wide open, on others partially blocked, and on some possibly even closed. The goal is to reduce the temperature swings on the discs as much as possible. That's what leads to cracking. Also, most brake pads have a temperature range in which they are most effective. So on an easy braking track with a quality big brake kit, you could possibly be running below your ideal temperature range if you have your brake ducts fully open with maximum airflow into the discs.
The temperatures your brakes see depend on the car setup/power/tires/driving style/and on course layout...how far is it between brake zones? How much will the brakes cool during that time? How heavy are those brake zones (140mph down to 50mph, or 120 down to 80mph)? The first step to finding out what works best is to record data as Dave-ROR is doing. Once you have your data, you can analyze it and work towards the best solution.
For example, in NASCAR Sprint Cup we provide the teams with different calipers and discs for each type of track. On a Super Speedway, they use the lightest setup possible to reduce unsprung weight. If you took that setup to Watkins Glen though, you'd fry them easily. For a tough road course like that, we provide them with a heavy duty package that uses a disc with more thermal mass. It just depends on the particular situation.
The point is, gathering data and knowing what your car is doing is always a good thing. With that info you can optimize performance. With brakes, ducts give you an additional tool at your disposal to do so. They add some flexibility to the system by either increasing or limiting the cooling airflow to the brakes. It's just like using a tire pyrometer. You can take temps across the tread block to figure out how much camber you need to optimize your contact patch. In that example, your camber plate/bolts/whatever would be the same sort of tool as your ducts. You adjust them based on the heat data for any given condition/situation. :thumbsup:
