-   Suspension | Chassis | Brakes -- Sponsored by 949 Racing (https://www.ft86club.com/forums/forumdisplay.php?f=59)
-   -   Is it worth the $$ to go Tein flex A over Z (https://www.ft86club.com/forums/showthread.php?t=125657)
vadim.totskyy 03-03-2018 10:21 AM
Originally Posted by new2subaru (Post 3052802)
Stay stock. Maybe a lowering spring.
Second that. Stock is perfectly fine for daily driving and occasional fast road (2017 version is a bit firmer imo). Lowering springs if you want lower.
Unless you want more aggressive wheels or go on track, I think stock car is very capable (much better than some hot hatches i test drove). I had couple track days and 3 training days on testing circuit and stock was great.
Sent from my SM-G930F using Tapatalk
EffaressNOOB 03-08-2018 11:40 AM
What if you need the clearance for wheel specs (17x9et45 245/40) and plan to track in the future? Flex Z or A?
vadim.totskyy 03-08-2018 11:45 AM
Either should be fine for clearance, but if you plan to track I would suggest As as you can adjust dampening. Makes quite a difference on some corners.
CounterSpace Garage 03-12-2018 02:46 PM
Originally Posted by carlovestela (Post 3052751)
How about pure daily driving only. No track. No autox.
Tein flex z?
Stock is quite good. For improvements of street comfort and spirited driving performance, CSG Spec Flex A covers these avenues quite well.
Inexpensive way to lower the vehicle for the nice look, but does not always translate to a good ride quality unfortunately.
new2subaru 03-12-2018 05:59 PM
Depends on the spring? I just ordered some RCE Yellows. From what I've read it's a decent ride.
CounterSpace Garage 03-12-2018 06:42 PM
RCE Yellow and Swift Sport springs are designed accordingly as lowering springs but still does a decent job at allowing the shock function.
carlovestela 03-12-2018 08:02 PM
How about trd?
Im using trd springs
CounterSpace Garage 03-13-2018 03:54 PM
Originally Posted by carlovestela (Post 3057325)
How about trd?
TRD = Toyota Racing Development
Their goal is to provide a system that provides a small enhancement to the factory system. It can be for looks, it can be performance, etc. Any lowering spring will give you something in the X category, but has to take away from the Y category.
