Sooooo, pretty much as I said it would go.
So, power was cutoff at 6600rpm, more or less? The effect looks similar to the crawford power blocks. If it has a full exhaust, then how can we tell those results are direct result of the ITB? Any before Dyno results for comparo on that page?
Juice ain't worth the squeeze folks.
One of the owners agree with that sentiment. The other one says he is determined to extract more from them so how.. Presently both used the supplied IM so I don't think they can play with runner lengths. It's pretty obvious the butterflies are undersized for a 12.5:1 comp 2.0l engine and unfortunately the TBs are already bored over from the original 45mm to 48mm so there isn't much material left to get to 50-52mm. However like I said earlier with a standalone and runners open atmosphere they start to makes more sense. This was on 94oct. https://i.imgur.com/UV4Y6Yf.jpg |
Yea, that actually looks pretty good. Sure, we all want more peak power, but the powerband is wider & stronger which would result in a quicker car. Downside is less high RPM fun... perhaps with some further tuning/development we could see better results up top. |
Needs larger diameter throttle bodies.
Correct, as I said earlier.. However at that point you might as well make your own custom kit and forgo the Greedy kit completely as you wouldn't be using much of it at all. Past racing classifications and novelty the cost to source50-52mm ITBs for this layout for the mid-range and last 10whp NA one could build a legit 2.2-2.4L for the same cost and not need a standalone to run it. :iono: |
| All times are GMT -4. The time now is 12:59 PM. |
User Alert System provided by
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
