-   -   Shifter rebuild kit? (https://www.ft86club.com/forums/showthread.php?t=125001)
radroach 01-28-2018 09:59 PM
I've noticed that mx-5 and s2000 owners often go for a "shifter rebuild kit" to fix their shifter, usually to fix slop or play that developed after a clutch install. The kits often come with all the necessary OEM bushings and grease to rebuild the shifter properly.
I was wondering if there was going to be a kit available like this for sale from any of the parts retailers here?
radroach 01-30-2018 11:42 AM
Bump. I'm still on the look for parts to fix my shifter. Going to try and replace the parts similar to this video, which are the pivot point, pivot ball, spring, and grease:
[ame="https://www.youtube.com/watch?v=dCEsP-wfXP0"]Honda S2000 Shift Assembly Rebuild DIY - Well Worth it! - YouTube[/ame]
Here's my problem now, I can't find an online OEM parts store that gives me a complete list of shifter parts. They used to be available but not any more.
https://i.imgur.com/rMw9AGA.png
Anybody help?
humfrz 01-30-2018 02:51 PM
Originally Posted by radroach (Post 3036164)
Bump. I'm still on the look for parts to fix my shifter..............
Anybody help?
Have you tried a dealers parts department ..... ??
What's wrong with your shifter ....??
humfrz
radroach 01-30-2018 04:32 PM
Hi @humfrz , my shifter has 1" of horizontal play in every gear after a new clutch install. It's been like this for a couple years really and I've never found a solution to fix it.
My dealership isn't super helpful over the phone. Last time I called a dealership we fudged around on the phone for 20 minutes just to find drain and crush washers, and when he asked me if I'd need them for my center differential I decided I'd be better off asking elsewhere.
Looking for a direct answer thanks. Parts numbers, where to buy, what to look for thanks.
tehShirt 01-30-2018 04:35 PM
https://parts.charlestonsubaru.com/a...10-350-01.html
The white "bushing" that goes around the ball isn't purchasable separately as far as I can see. You could always clean and re-grease it.
The bushings that attach to the bottom of the shifter are 35025CA000.
Osment918 10-15-2018 12:16 PM
Did you find anything to reduce shifter slop?
