Sorry to hear the FR-S is going, but we all change in our vehicle situations in life. Question though, any particular reason you are looking at a 4 cylinder Tacoma instead of a 6-cylinder one? Especially being a 4x4. I had a '98 Tacoma 2.4L 5-speed manual 2WD extended cab that I loved, or thought I did. Then I picked up a 2013 Nissan Frontier 4.0L V6 2WD King Cab with 6-speed manual this year....way better than 4 cylinder truck for 'small truck' stuff, and quicker acclerating than the FR-S even though it's got a good 1600lbs more weight and worse aerodynamics!
Don't miss the Tacoma one bit compared to it. Fuel mileage is not hugely different than 4 cylinder models, but the truck has more capacity and can get out from under it's own weight with the V6...sucker really boogies and sounds great doing it, and I can confidently chuck it into turns at high speed. I could never go back to a 4 cylinder truck after the V6, unless it was a turbo-diesel that made actual power. I did crazy things with my Tacoma and it didn't complain much, but the 4-cylinder motor was definitely it's weak point unless you only plan to mainly use it like a car for a daily driver. |
The main use for the Taco will be a DD. Any towing or pulling I do with it will be around the property or 2 miles up the road to the in-laws farm. As low on power as the 4cyl Tacoma is, it will do a better job of moving a portable wood processor or a wagon load of hay around the property than the FR-S would. If we need to pull something heavy more than a few miles, we can use dad's 3/4 ton Silverado. We heat the house with wood, and between my wife and her sister, there are 20 horses to be fed, so there are always things to be moved around.
I can handle gutless...I also have a Chevy Tracker. |
Lol, no kidding. However, I'd still take the 3 hour drive to Ottawa over the 2 hour drive into the GTA any time. |
A friend of mine had an early one many moons ago. I think it was an SJ410 or samurai, a little tin top. That thing would climb a wall if it could get traction, and go lots of places the full size trucks couldn't get to. Mine is more like a Suzuki Grand Vitara. It's still pretty nimble, light, and small, but not on the same level as the earlier ones. |
They are planning a cruise for Sept 24 over on the Ottawa FR-S thread. http://www.ft86club.com/forums/showt...=5626&page=756 |
That is one of the best runs in Ontario. Do your self a favor...when you get to Sharbot Lake, head south on 38 to Verona, and turn off on Desert Lake Rd. It is only 20-30 mins to do that road, and it is in the middle of nowhere, but worth the drive...makes the 509 look like a straight line. A little closer to you, there is another good series of roads. Take Rd 23 North from Peterborough to the 507/648/county Rd 10 run. That will take you up to the Southern edge of Algonquin Park. I've done this run, and it is fun as well. Also in this area is the 504, CR 3, Hwy 118, and some others that look good on the map, but I haven't had the chance to try them out myself. Have fun, and be careful. The 509 has a lot of elevation changes, decreasing radius corners, blind corners, and sudden corners at the top/bottom of hills as it threads its way through the rocks and around small lakes. |
On that note.
| All times are GMT -4. The time now is 09:42 AM. |
User Alert System provided by
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
