-   -   Long term build (https://www.ft86club.com/forums/showthread.php?t=120922)
Zer0 08-28-2017 06:27 PM
2 Attachment(s)
It has been over 105° this weekend and will be around that all week. Needless to say Im not doing much to the car until it gets a little cooler.
I DID get a hole cut in the firewall to eliminate a section I didn't like, and possibly run the heater lines through. I decided to keep the firewall smoother, and run them through the area where the windshield wiper motor is.
Next on the list is to build the lines from the blower assembly into the engine compartment, and button up the hole in firewall around the new lines.
Trying to decide if im going to send it out for paint in the engine compartment, firewall in the passenger compartment, or just rattle can it in the garage. Im leaning towards sending it out after I get it all smoothed out and prepped. Im not a painter.
Zer0 09-12-2017 01:26 PM
2 Attachment(s)
Sprayed primer on firewall to prevent rust until firewall mods are complete, and it is ready for paint. Made the last patch panel will weld it in smooth it out and send it to paint. Hopefully by next week.
Zer0 09-14-2017 04:38 PM
Bulkhead for Ac lines and heater core lines arrived.
Zer0 09-20-2017 09:46 PM
2 Attachment(s)
A little progress.
ILLSMOQ 10-26-2017 02:49 PM
Looking good...big fan of the clean firewall idea.
Zer0 11-10-2017 10:57 PM
Thanks. Trying to get back out to the garage soon. Nice cool weather lately.
Zer0 12-03-2017 06:41 AM
3 Attachment(s)
Pictures of the clutch mater cylinder relocation bracket I made. I will post pictures of the modified pedal assembly to go with it today when I get home.
Zer0 12-05-2017 03:40 AM
4 Attachment(s)
Modified pedal assembly to line up actuating lever to master cylinder. Moved 3" to the left.
Zer0 01-13-2018 07:37 PM
Ordered Sabelt gt160 seats, aluminium mounts, and 6 point harnesses with aluminium adj
Also ordered a multipoint Cage produced by Custom Cages.
If all goes well, and they don't get held up at the port I should have everything next month.
Zer0 02-22-2018 03:23 AM
Cage arrived. Still waiting on my seats, harnesses, and mounts. Going to order custom cages seat mount tube kit, and welding rod Friday. So I can get rolling on the install when I get the seats.
Zer0 02-24-2018 01:16 AM
Seats, harnesses, and brackets arrived pictures coming soon.
Zer0 02-28-2018 04:11 PM
Pics of seats
Zer0 03-15-2018 12:00 AM
2 Attachment(s)
Cleaned up the garage, and moved some new tools, and parts in. Roll Cage, jacking points, stands, and seat tube Kit's for mounting seats. Produced by custom cages out of the U.K. Purchased from rma in Colorado.
Zer0 04-20-2018 10:29 PM
Will be starting to strip the seam sealer out and seam weld soon. I plan on using internal frame sealer from Eastwood to seal up internal areas I can't paint after stitch welding to prevent rust. Anyone with experience stitch welding and coating areas after welding input is welcome for best products, to methods. Thanks in advance.
