| lutfy |
05-24-2017 01:11 PM |
Originally Posted by ayyyypex
(Post 2915543)
Hey guys hope everyones day is going well.
Im looking to buy suspension which is good for the track (i dont care about how low i can go, stance or any of that) im looking for something i can purchase now and use for a while till my driving experience is at a point where i can upgrade to something better. The car is driven on the street, but sees the track through the season. Im competing in time attack. Ride quality for street driving doesnt matter to me, just want something oriented for the track. Budget for now is around 1800 Cad, give or take. Either coils or a koni setup. I dont know much about suspension which is why im asking you guys, especially because some of you have experience with different brands and setups.
Car is stock motor wise but will see boost in the next year. I want something which i can be using for a while, not looking to have to upgrade multiple times. Ive seen BC Racing, HKS, Bilstein, ST, KW, etc. Just not sure on which ones i should pull the trigger.
Thanks.
I am in a similar situation. My car is classed for NASA TTE (its a points based class). I used them as follow:
1) Better tires (Azeni+ in stock size since anything wider or running RE71R etc I take more points)
2) Adding camber!! This is a free mod. Car comes to life with front camber. I tried the crash bolts and it was not enough (-1.5) with bottom bolts its at -2.5 and its a must (possibly the biggest gain you will see bang for buck not including better tire wear).
3) My car came with the TRD springs so I cant compare to stock but I can tell you that it helps with more camber especially at the back (static).
4) Got TRD bars installed and am taking the stock rear bar with me next time I go for test/tune on the track.
5) OFT Stage 1 flash since its a free mod in my class.
So I am pretty much done with the max rules for now. Is the car tossable, fun at the limit, manageable (rotate on demand), yes.
Just a suggestion, try the camber and better tires first and take baby steps. If you intend to get suspension, dont get the street stuff and save for the motorsport ones especially if you are in time trial series. I have my eyes on the MCS Doubles with remote but am waiting for the rules change with NASA TT for next year (hence running in a lower class this year).
I have tracked/raced on other cars with streetable shocks (Clubsport etc.) and with race suspension such as JRZ/MCS/Ohlins before and after and the difference is pretty pronounced. Especially in the rain! Will you beat the competition by a long shot, no but every 10th here and there adds up.
Once you differentiate between DE (open track) and TT (or building for a series), its best to do it once and do it right rather than upgrading later (false economics).
Lutfy
