-   -   Rod Knock on leased FR-S (https://www.ft86club.com/forums/showthread.php?t=117857)
Urmyson 04-22-2017 04:11 PM
You could get a used motor for under 2k with high miles. Find a friend to install it and you are on your way.
tony707c 04-22-2017 04:44 PM
Thing is, its leased and I wanted to return it at the end of the year. I doubt Toyota will accept the car with a different engine.
Lorico 04-22-2017 06:09 PM
Sounds like you're going to have to suck it up and learn the hard way. Tricking someone like you tricked yourself thinking your car didn't need maintenance is foolish.
tony707c 04-22-2017 07:06 PM
I never said I was going to do that, my friend threw the idea out there. Thanks for the input though. It appears I will have to learn the hard way.
Token11b 04-22-2017 07:09 PM
Guess you just bought yourself a 2015 frs. Congrats bro!
Sportsguy83 04-22-2017 07:59 PM
You can replace the engine, have the car running and return it later this year. Engines have no numbering or marks tying them to the car.
imnotsureaboutbrz 04-22-2017 09:05 PM
Here's an engine...
http://www.ft86club.com/forums/showthread.php?t=117893
Lorico 04-23-2017 10:33 AM
That's awesome. I always thought they had vins etched into them like any other body panel
Sportsguy83 04-23-2017 10:36 AM
Some cars do, but not this one.
tony707c 04-23-2017 02:49 PM
The tech at the dealer told me that they do so I don't know if he's not aware or what?
Going back tomorrow hopefully a miracle will happen.
Sportsguy83 04-23-2017 02:59 PM
I may be mistaken, but I've looked at a few engines and have never seen a Vin etched on them
Decay107 04-23-2017 03:29 PM
incorrect.
https://i.kinja-img.com/gawker-media...iqqs8t5mm5.jpg
Sportsguy83 04-23-2017 04:26 PM
Originally Posted by Decay107 (Post 2897429)
It's probably even a requirement to have them for this day and age I stand corrected. Thanks. Learn something new everyday.
Turdinator 04-24-2017 04:02 AM
I had a similar experience. My engine developed rod knock after 66,000kms. It was a year out of warranty. Toyota wanted $2k just to diagnose the problem. I ended up sourcing a low km second hand motor and throwing it in over a weekend with a mate. Toyota did suggest they might show "good will" depending on what the dealership found. I decided it wasn't worth the risk of Toyota not covering anything.
My motor definitely doesn't have the car's VIN number on it. There is only the engine number. I would expect Toyota would have a listing on what motor went with what chassis if they really wanted to check into it.
