My seal does the same thing. I also noticed a dent in my fender with NO damage around it. Anyone else have that issue?
My window freezes hard to the seal and won't roll down, I'm sure me trying to force it down to get a smoke is not helping the seal. Is this the issue being talked of in this thread. I was thiking of coating the seal with Vaseline?
This stuff is top notch and should solve your issue and use it to Treat all the rubber seals.. Small tube, pricey stuff.. But it will Last you a long time. |
Finally happened to mine -- I'm heading into the dealer next week to see how/if they can handle the 'folding seal' issue. Hopefully they've seen the issue before.
Mine has been doing the opposite, dragging the rubber down into the window slot when I roll down the window. Makes a super loud screeching noise.
Roll it up, rubber comes back, all is quiet. Granted it did that after freezing rain and I haven't noticed it since. |
I'm seeing this as well. No extra wind noise but about one time out of twenty the window won't roll back up all the way after I get in the car. It seems to settle in after I hit the window up switch.
Sent from my SCH-I535 using Tapatalk |
I took my car to a dent spot and they said they can get it out for $99 + 15% mil disc. I'm going back there next Sat.
My window would pinch the rubber seal and fold it up. Took it to the dealer last weekend and they replaced the window seal. But the "Buzzing" window switches are "normal" lol
Finally made it into the dealer and they said that although they couldn't reproduce the rattling shifter or the passenger side window 'auto' up problem they would do those TSBs anyway. But I'm disappointed they had never heard or seen the problem with the driver's side window pinching the seal when rolling up all the way. The reply from them was basically, 'lets wait and see what happens'. Not sure if they are expecting the car to heal itself.. But it isn't anything more than a quirk at the moment. I'm not terribly concerned that it will get worse but also not terribly impressed with the response either.
I'm onto driver door seal number two. First one was leaking water when I washing it, so was replaced. Not long after that I noticed an increase in wind noise from the area, so they have replaced it again.
| All times are GMT -4. The time now is 04:13 AM. |
User Alert System provided by
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
