| VerusEric |
07-06-2017 03:42 PM |
Originally Posted by PulpBrah
(Post 2941073)
*shoots self* this will be fun. What's your recommendation for grease?
Originally Posted by Ultramaroon
(Post 2941077)
That brings us back to the Lucas Red & Tacky #2. It's "equivalent" to the Nichimoly specified in the service manual.
But I have some not-so-good news about it. I cleaned and re-lubed mine last summer. It just started hanging up again last week. I also have to take mine apart again. :(
On the Fork-to-TOB, Fork-to-Pivot, Fork-to-Slave, and finally TOB-to-Input Shaft locations, I have always used Sil-Glyde. I was taught this by a master-tech from Toyota when I was an apprentice and worked at a Toyota dealership for 4 years. It seems to do the trick well from my experiences. It is a high-temp silicone lubricant which does very well with temperature/dust/dirt/grime/elements/time/etc.
https://shop.advanceautoparts.com/wc...4_pri_larg.jpg
There are plenty of lubes that you can use that are equal to this and it looks like the Lucas stuff should be good to use as well. I think the big thing is to lubricate all the locations necessary with a decent grease.
I would never use any spray type grease, it doesn't have enough substance to last.
Hope this helps some.
Thanks,
Eric
