OK, time for lights out.
Pa-pa and Ma-ma are on a new schedule starting tomorrow. Daughter started a new job and has a longer commute. Granddaughters will be arriving at 0715. Nite all ........... ZZZZZZZZZZ |
I am wary all the same. They (Fluidampr) are trying to sell their product. I look at their graph and say to myself "Holy shit! Just look at the difference their damper makes!" That is the intention. I am not suggesting what they are saying is incorrect but.. So what if the "vibration angle" goes from .225 to .05? Let me state I DO NOT KNOW ok? But sure it looks good in their sale pitch but why is it significant? Crankshafts oscillate and providing there is no nasty resonance I don't understand the issue. I've read another part of their article: "Crankshaft driven timing components and oil pump drives can be more susceptible to these high frequency vibrations." My bold. That looks like marketing speak to me. They don't say "it does" they say "can be". As in might be, possibly, maybe. Two other points: 1/ There has been no controlled testing of the effect of fitting a solid cp on the FA20 as far as I know and it would not be economically viable to do so. 2/ There doesn't seem to be a high correlation of engine failure with having fitted a lwcp. |
Captain Snooze: regarding (2) i recall seeing posts from few shop workers about crank bearings having short live for EJ & FA engines they had rebuilt or repair for cases where both lightweight CP & FW were installed. Rather soon at it. Something along the lines that only one of them should be installed, not both.
Fluidamper also claims 2lbs of rotating mass does not behave as rotating mass...
I know nothing of harmonics in an engine, but I see only that harmonics exist on all 3 pulleys, with similar magnitude, but in different orders and rpm. And the OEM pulley seems worst of the bunch on that 2nd order line... But what's actually destructive? No idea. I tried researching but haven't found any materials... It could be NVH is the only reason for a damper pulley. Of course, the OP's wobbly install would definitely be bad. C |
One of those posts of different experiences. Another. Later cites info from other shop doing even more rebuilds and with "similar experiences". It's my only car, and one i like & want to use for long time .. preferring to play on safe side.
1. The OEM commits considerable resources into understanding how each component responds to the environment in which it operates. The customer is not privy to the mounds of information collected but it exists. 2. I agree with you on this point but that does not mean I think it's a good idea. |
Speaking of which. There seems to be a lot of discussion about the pros/cons of a light weight crank shaft pulley but I don't seem to read much about the impact of a light weight flywheel on the harmonics of a crankshaft. I am hypothesising given the much greater mass of the flywheel it would play a greater role in crankshaft damping/harmonics. I am totally out of my depth here. |
As someone considering getting a lighter flywheel at a later date, I too would like to know how a lighter flywheel affects damping on stock cp.
I hear the mass of a flywheel allows it to absorb some vibration.
Sent from my Pixel XL using Tapatalk |
But you've struck a good point, there are engines that are way out of balance and need all sorts of things to make it not blow up. Some people decided that since some engines need this that must mean all of them do, which is of course nonsense. There can be no clear failure of pulley's as it is not something people would do and never modify anything else. People do claim they have seen ej's and fa20dit's with failures in cars that happen to have lightweight pulley's among a bunch of other mods as well. Of course the problem is we are seeing failures in both engines in completely stock cars as well. Quote:
I hate when people say the stock way is the best way, instead of the way they compromised for everything because they have so many other goals and qualifications other than making the car as sporty and fun to drive as possible. While the aftermarket has that one goal and can easily cost a heck of a lot more than the stock part it replaces without issue. |
" More complexity changes things, however that article I posted trying to sell that so called damper proves everything has vibrations, and even the fancy expensive aftermarket damper sold as smoothing everything out actually just changes the vibrations and has more vibrations than the stock ones. "
Man, are you reading the same article? Because it actually says the opposite. Or is it again based on your extensive experience? Alternative facts? Look I get it, it might be a marketing spin, but considering Fluidampr has been around for years, had stellar results on trucks and cars, and been tested independently by quite a few places, i tend to believe them instead of your personal uneducated opinion. No disrespect, just a choice. ;) Here is another one that might interest you. http://www.motoiq.com/MagazineArticl...dent-Test.aspx |
Here is an educated answer from an engineer:
The crankshaft damper has nothing to do with engine balance and vibrations. Motion and oscillation of the powertrain, as an assembly, is addressed by your engine mounts, transmission mounts, and potentially roll restrictors. The purpose of a crankshaft damper is to reduce the angular twist / deflection of the crankshaft. Combustion creates pressure. Pressure becomes load into the connecting rod which creates torque on the crankshaft. That torque creates deflection of the shaft as it's not infinitely stiff. Depending on the material, journal offset, length of the shaft, and loads created in the cylinders you can see several degrees of angular deflection in the crankshaft. I've seen an OEM crankshaft which displayed 7° of deflection without a damper. With the damper it was under 2°. The mass of the crank damper and the stiffness of the spring element (the rubber part) are vital to the effectiveness of the damper. They control the resonant frequency of the damper and impact the effective damping. If you change the mass or change the spring stiffness you change the frequency at which it operates. If you don't have enough mass, even at the correct frequency, you don't provide sufficient damping. An incorrectly tuned damper could actually make things worse." |
Attachment 149553 |
DANG ...... this ol boy may be confused .......:confused0068:
@why? ....... are there two of you with the same forum name of "why?" .. ?? Back a couple months ago a "why?" started a thread entitled "Help with essential basics". I quote: "Help with essential basics ________________________________________ So I don't see any threads with this type of stuff, probably because it is obvious to most. But I've never really done my own maintenance on my car and have no real idea of where to start. Basically I want to be able to change my own oil, rotate my tires, etc, start with the simple stuff, but I need the tools. I have a set of basic tools, aka wrenches, hammer, measuring tape. I have a dirt with some gravel driveway, so I don't trust the jack that came with the car, and I know there are all sorts of different ways to raise the car for both oil changes and changing tires, what are the easiest and least expensive tools for someone getting started? What other basic type of stuff do I need to buy that a beginner wouldn't even think of? I obviously need a good jack, stands or something to keep the car off the ground, a good torque wrench for the wheels,etc. I've seen special wrenches for oil filters, but is that really necessary? What type of containers do people use to drain the oil into, where do I get them, and what do I do with the used oil? What else would be handy and what other basic maintenance would a beginner be able to do without too much hassle? I know I have the ability to do this type of stuff, I just don't have any clue about how or where to begin and I am looking for help". ---------------------------------------------------------------- Now, starting yesterday, a forum member named "why?" started posting in this thread like he/she was some kind of automotive engineering expert. Are you one in the same "why?" .... ?? If so, how did you get so automotive smart and experienced in a little over two months? :popcorn: humfrz |
These tests are ordered by the manufacturer and obviously they will be biased, unless the product is utter shite! On the other hand, I would somewhat trust some professional tests rather than some guy on the forum. Generally speaking that is. |
Please take that with my intended humor. I just found the self defeating comment funny. |
You on the other hand...dont know man! You just post pics of borderline work appropriate pics, and that is about it. :) JK man! :cheers: |
You can also go check other actual forum members who run lightweight everything on these cars, but I guess you don't give a crap about real world knowledge, do you? You just want to make baseless personal attacks. Go for it. huge difference between book smart and practical being able to do anything. Same reason those ASE certifications can be dubious, they are all book testing with no actual practical testing. You can become an ASE certified anything just by studying and memorizing without any actual experience in the field. I can give you theory, research and boatloads of actual knowledge. I've never claimed to be a mechanic nor will I claim to be able to do much wrenching myself. I just don't have the room or the place to do my own maintenance, that is what happens when one lives in a 750 sq foot apartment in the middle of nowheresville. I've got a dirt and rock driveway and everyone says that is a bad deal for lifts. I can also read marketing bullshit and see when graphs literally say the opposite of what an article says. But sure attack me because you don't like what I say. Still no proof any pulley alone has ever caused any damage anywhere on our cars, and I highly doubt you will ever find it. Still zero proof that anything on our car is a harmonic anything. Nor is one needed. Quote:
And look, I have never said anything against that fluidampr damper. No idea why you think I have. I have just said their graphs show their damper causes more vibrations than stock in certain areas, which is 100% true. They also do not define anywhere if any vibrations their graphs show will ever or have ever caused anyone any actual damage in any actual cars. So those graphs might look pretty but they prove nothing. That other article states the same thing. Three pulleys that all make a hp and torque figure that are easily within the error correction of every dyno ever created. Could they actually be legit? Sure maybe. But the difference is so tiny as not to matter. Then they give their opinions that everything is smoother with the fluidampr. Which again might be true, but could also just be bias knowing it is suppose to be smoother. Who knows. |
This post is intense, so... to keep it going:
Yeah I'm not even gonna bother cleaning this mess up.
| All times are GMT -4. The time now is 07:24 AM. |
User Alert System provided by
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
