At what RPM are you making 400whp? Cause at peak torque you're only making 276hp. Assume you hit peak HP at 7k, You'd need 300 torque. Even at 8k your cars torque would need to be higher than what you stated as your peak torque. Your numbers don't add up. |
Heres a pic of one of my Dyno runs for reference.
:suicide: |
Now that I'm pretty close to having the funds for the edelbrock kit I'm contemplating about a 2002 996 Carrera s I saw in an add..
it's priced the same with the resale value of my gt86.. and the funds for the edelbrock kit can go to any maintenance issues Sent from my HUAWEI NXT-L29 using Tapatalk |
I too have noticed late shifting and some slippage when going form 1st to 2nd and 2nd to 3rd. When really on it I have to shift a good 1-2 seconds before I want it to actually shift. I'm currently in the 350-380 WHP range on 265s and I'm trying to figure out what all I can do to beef up the trans.
What trans fluid are you boosted guys using?
The next big purchase for my build is building the trans. But I really want to swap in a ZF 8HP having 6 close ratio usable gears instead of the 4 capable of handling plenty of power and swapping to a 3.7 FD with 400whp+ would be amazing. Just don’t know what would all be necessary for the ZF swap. |
Im torn between doing clutch pack / valve body or attempting a swap to a different auto.
Wish someone made an easy solution to swap in a ZF 8HP. An 8 speed with 6 usable gears and holding 400+wtq with ease would be amazing. 3-4 is just too long we need an in-between gear and then 5th is not really usable. |
| All times are GMT -4. The time now is 09:20 AM. |
User Alert System provided by
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
