-   -   2013 Cars and FI (https://www.ft86club.com/forums/showthread.php?t=113182)
Yoda 11-23-2016 09:32 AM
2013 Cars and FI
I remember a post a while back stating that 2013 models were not as reliable when going FI. I can't seem to find that thread or post.
Does anyone know of any areas of concern when going FI on a 2013 model?
go_a_way1 11-23-2016 09:38 AM
I'm driving a 13 with a turbo. Cars gpt 65k KMS on it pushing 10-13psi
Luftwaffel 11-23-2016 09:53 AM
Generally speaking, any first model year has more issues. I seem to remember a VVTI/cam issue being the big thing with 13s?
Yoda 11-23-2016 02:16 PM
Maybe that was it. Was there a fix for that issue? I have 50k on the motor and will be going FI next year spring. Just want to make sure everything is good before that.
Phantobe 11-23-2016 02:27 PM
I've read somewhere that rocker arms are different PNs from MY13 & MY14+. If they're better or different no idea, could just be supplier change.
go_a_way1 11-23-2016 02:36 PM
I can confirm they are different PN. I thought I had a rocker going for the longest time and I just found out its likely the vacuum pump running off one of the cams lol. First major issue with my car and its been doing it since almost new.
Tcoat 11-23-2016 02:37 PM
There is always risk when going FI. The issues that the early 13s had may raise that risk marginally but it would not be significant enough to worry much about. Odds are if you haven't had the problems now even at stock then they will not impact your FI setup.
ajcarson11 11-23-2016 07:56 PM
I'm running SC 10lb of boost (give or take) on a '13 and seems fine. Course, everything will probably seem fine until it goes :)
mrk1 11-23-2016 09:30 PM
My '13 is boosted, no issues.
kmbkk 11-26-2016 08:14 PM
I've been FI for 50k+ miles with no issues on my '13.
weederr33 11-26-2016 08:32 PM
My car is a 2013 model and I've been supercharged for over 20K miles. So far, so good.
Yoda 11-26-2016 08:59 PM
This is making me feel alot more confident.
Andew727 11-28-2016 09:45 AM
i have the VVTI, cam sensor, oil control valve nightmare going on. not till after i built the motor though.
jwvand02 11-29-2016 05:38 PM
It was chock full of the same guy basically saying "13S ARE WORSE CAUSE I SAID SO DONT NEED TO PROVE IT LOOK AT THE FORUMS"
