-   -   57c6 - Will it work on my suspension? (https://www.ft86club.com/forums/showthread.php?t=110812)
ikarntspel 09-19-2016 10:23 AM
Hey all,
Ive read alotttt of different threads on this topic but i always seem to see different answers on this. Ive also tried the calculators and stuff but it always gets me confused :bonk::bonk:
My question is will 18x9.5e40 wheels with 255/35/18 tires rub? Im currently on King springs and shocks.
Thankyou for any help :)
8R6 09-19-2016 02:21 PM
are the "King springs/shocks" the same diameter/size as the oem springs? Or are these adjustable coilovers with skinnier-than-oem-springs diameter?
If those are basically replacement lowering springs, that wheel/tire combo will rub.
Bowen 09-19-2016 04:23 PM
Unless you have coilovers, basically any 9.5 wheel will rub on the factory suspension. You can get away with a 9' wheel with some more poke and a slight spacer, but there's no way of getting around the rub of a 9.5' wheel.
vincelive123 09-20-2016 01:50 AM
i had 18x9.5 +40 offset. I also had lowering springs from eibach(same size/radius as stock springs) YOU WILL NEED a 5mm spacer in the front to clear it while turning. The 5mm is a perfect fit with that size of a wheel. I also ran a 3mm spacers in the rear. I drove it for over 10,000 miles with no issues...
austinbrz 09-20-2016 10:28 AM
57C6 with Stance Coilovers
18x9.5 Rear with 265/30R18
18X8.5 Front with 245/30R18
Lowered and on Stance Coilovers with zero rub...
Shown here next to my son's stock wheels and suspension.
https://c7.staticflickr.com/8/7070/2...9e5c123a_k.jpg
ikarntspel 09-21-2016 12:02 PM
Thanks for all the replies :) i did some measuring and i believe its the same size (Spring diameter and the spring perch)
Does it only rub on full lock? or just when you turn in general
Also wanted to ask, if i did put 5mm spacers at the front would i need to do the same with the back?
vincelive123 09-21-2016 02:06 PM
the front will start to rub as soon as you turn the wheel.... the spacers on the rears is totally up to you what size you wanna put & how you want it too look... 5mm or 3mm in the REARS is up to you.
ikarntspel 09-22-2016 12:47 AM
So with 5mm there will be NO rubbing at all?
Thanks for the help
vincelive123 09-22-2016 02:04 AM
Thanks for the help
That is correct. With an 18x9.5 +40 offset
ikarntspel 09-22-2016 05:31 AM
Not that i dont believe you but can anybody else confirm this?
