I do a lot of highway driving and its amazing the junk that I pick up on the front of the car. Additionally I tend to pick up dirt around the fenders as I have quite wide wheels/tires. At any rate, i'm used to washing once every 2-3 weeks or less. So I may find that I don't need the power washer if I can wash more frequently. Thanks for your input! |
Always cool to hear about people stepping up their wash game. A few thoughts and recommendations:
In regards to the pressure washer, 2000psi is sort of on the high side for a vehicle, I would prefer something in the 1600-1700 psi range if possible. A foam gun looks cool, it may or may not actually show any improvements in grit removal and to be honest just a pressure washer rinse should be enough but it can never hurt. I am surprised your having grit still on the surface after washing. I think there is a possible kink in your technique or materials. What type of wash mitt are you using and what type of soap? Are your jambs completely clean? sometimes the hood or trunk jambs can leak dirty water on a clean car when you rinse. I would also recommend to you to get a mild clay bar and clay the car at least 1X per year maybe more depending as needed. In regards to protection. I would certainly recommend a paint sealant and possibly a wax topper. Two combos I have used in the past before moving on to coatings. Probably one of the easiest to apply is Optimum Opti-Seal and topped with Opti-Wax. Both preserve the clear coat with UV protection which is very important, will keep the paint clean and both are extremely easy to apply and maintain. Second combo I would recommend Sonax Polymer Net Shield as the sealant and Sonax Brilliant Shine Detailer as the topper. Brilliant Shine is actually a spray sealant so don't let the name fool you. Now they are grabby to apply and require more technique but they bead water like a coating. One of the big reason I recommend both the Optimum products and Sonax products is that they can be applied to ALL areas of the car, paint, trim etc. I personally like that I can protect everything with one product. Feel free to ask any questions and good luck. |
I'll definitely give the clay bar a shot -- as well as the sealants/wax boosters you suggest. Thanks! |
humfrz |
Everybody's needs are different depending on where you are in the states. The Socal folks are always going on about your waterless washes and detail sprays, but in the Southeast that doesn't work because we have way more pollen and bugs.
So I say use a detail regimen that works for you in your environment. For me, my car sits outside 100% of the time and needs a weekly wash for all the dirt, pollen, brake dust, bird poop, grass clippings, mold growth (yeah ew), and bug guts etc. My car has a few marks and scratches so I always keep a fresh coat of wax to keep them from showing up too much. And I just got on the grit guard bandwagon. Man what have I been doing without these! So much dirt! |
You can always try a Ceramic coat. it's expensive from the getgo but eliminates the need to ever wax your car again and all you need is a power washer to get off any dirst or pollen.
| All times are GMT -4. The time now is 07:28 PM. |
User Alert System provided by
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
