-   -   Harrop TVS86 Owners Thread (https://www.ft86club.com/forums/showthread.php?t=108698)
Irace86.2.0 12-09-2023 01:11 AM
Originally Posted by M0nk3y (Post 3597993)
Interesting moreso on the HX Core internal.
Obviously relocating the outlet/inlet opposing means they're most likely going to a single pass HX versus prior which was dual pass (assuming...I haven't looking to my own HX to confirm).
Regardless, would certainly agree the AN Lines are slick
It could be just for their track setup. I don't know the advantage or disadvantage of either setup, but I'd imagine single pass would be cooler.
CSG Mike 12-11-2023 06:22 PM
Harrop kits are back :)
M0nk3y 12-15-2023 08:46 AM
Assuming pumping flows and everything else are the same (even going into the fins per inch within the HX itself) it would result in less cooling. As well you'd have a temperature gradient across the core itself as water flows from front to rear (or vice versa).
Now with that, they could have been able to increase pumping flow across a single pass to up the capacity of the heat exchanger, or add more fins per inch (at a negative impact to airflow) to increase heat exchange effectiveness.
Or, it can be something crazy like a 3-pass system.
