Hey All,
Does anyone know what sort of horsepower/kilowatts the Harrop supercharger is capable of making say with a bigger pulley and a fully built engine. Also is there much supercharger whine? cheers |
Probably similar to the Edelbrock since I believe they use the same 1320 TVS blower. TJ Hunt just put down 420whp with E85 on an Edelbrock kit with a smaller pulley and a Delicious tune. |
No loud whine. You do get a little whirring sound under boost but no twin-screw whistle. There is a little more noise at idle, mostly just the sound of the gears linking the two halves of the roots blower. The gears are at the back of the unit so they're right behind the dash.
-Matt Sent from my XT1095 using Tapatalk |
From what I have seen the harrop is a tad better than the edlebrock in terms of IATs. |
What's the minimum pulley size that's safe for 91 AKI at altitude (~4k)?
I'm from flat land, but am about to take a cross country trip. |
Ok Guys...
Minimumn Pulley Size is 65mm - Requiring E85 to avoid Knock. should see 17-18PSI Our car is running the 2.1l HKS Stroker Kit, and the 65mm Pulley, Plus some new enhancements making 315KW At The Hubs. Thats 422HP, and then to convert that to Engine HP, which you americans love.... factoring in a rough guess at 20% Drive Train loss thats 506HP at the Engine. Hows that sound???? We run this on our Track Car, with no Issues with IAT, Please see the below chart with our track data from our MOTEC. http://bit.ly/23aa1gY |
Come down and have a chat? happy to show you around and work it out with us. |
@HarropOz - So what power does the harrop setup with the stroker kit and the 65mm pulley make on Ron99 rather than E85? You mention require E85 to avoid knock, but surely you can back off timing?
E85 is scarce here in the UK.... |
If you want to run a high boost pulley you should really build your engine with a lower compression ratio. High CR builds are fine for turbo cars that run E85 since you can easily back off the boost when running the car on 91-93 fuel and run high boost on E85 making big power. With superchargers you can't change the boost on the fly so if you're not going to be running E85 all the time you have to pull a ton of timing to avoid detonation.... and if you pull too much timing your EGTs will skyrocket causing other problems. A lower CR engine should allow you to run the higher boost pressures on regular pump gas but also extract some extra power with more advanced timing when on higher ethanol content (Assuming a flex-fuel setup).
As an aside... I would really like to see some manufacturer incorporate a little CVT pulley on a supercharger kit for our cars. This would be the ultimate SC kit, in my mind. The ratio between the engine RPM and the SC RPM could be varied infinitely in real time to achieve whatever boost level you want (within reason, of course). Want to hold 10PSI from 2000 RPM to redline? Just adjust the CVT as revs change to maintain that pressure. Want to increase boost when running E85? No problem. This technology is just hitting the market http://www.fallbrooktech.com/accesso...s/supercharger That company developed a clever CVT design for bicycles several years ago and has recently beefed up the design for use with superchargers. |
| All times are GMT -4. The time now is 06:15 AM. |
User Alert System provided by
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
