Tune systems for FRS GT 86 BRZ
Quick summary of tune systems that are popular on this platform. Tactrix/Ecuflash Open source No tunes supplied No lock on tune No locks on ecu Can read and write to any vehicle Can do standalone logging to SD card in Tactrix adapter Laptop required to read/flash tunes and download log files Cheapest system but little support, more for the DIY tuner or advanced user Many tuners will not tune with Tactrix/Ecuflash as they cannot lock the tune to prevent copying More info see here http://www.ft86club.com/forums/showthread.php?t=62332 Tactrix Adapter will work with Techstream software for realtime logging if required http://www.ft86club.com/forums/showthread.php?t=35530 You need a Tactrix adapter for aprox $170 USD www.tactrix.com Some opensource tuners have written code or have access to flex fuel, overboost cut launch and Flat foot shift features OFT – Open Flash Tablet Mid priced system easier to use than Tactrix more support and has supplied tuned roms. Open source tunes supplied can be edited and changed by end user No locked tunes No locked ECU Tunes supplied with device included in price (free) Marries to car by reading you original rom into device, original rom stored in device Can be un-married by writing original rom/tune back to ecu Can only flash vehicle its currently married to. Can be uses a multi-gauge , display engine parameters real time Some extra features on some roms such as launch control Flat foot shift. Flex fuel support on limited roms overboost protection on some roms Has alert/alarm function for engine parameters You can self tune with OFT The OFT can log and read and clear DTC on any BRZ/86 The OFT can also be converted to use on Mazda and BMW cars Many tuners (other than OFT guys) will not tune with OFT as they cannot lock the tune to prevent copying. Whole system can be onsold if unmarried Laptop not required to log or flash tunes or read/clear DTC Laptop required to update tunes in device and device firmware More info see here http://www.ft86club.com/forums/showthread.php?t=71157 You need the OFT flash device (includes tunes) for aprox $500 USD www.openflashtablet.com Brzedit Mid-priced system Uses Tactrix adapter to flash Has very good logging software with dash dispalys http://www.epifansoft.com/brzEdit-video-tutorials.html Much more support and advanced logging than Ecuflash Various software levels can be purchased. Tunes are locked and encrypted and cannot be used by other systems Ecu’s flashed with BrzEdit are locked until you flash back a “stock” tune to ecu. Tunes supplied by tuners will generally be locked/encrypted so not editable by end user Uses a different encryption/lock system than Ecutek so not interchangeable No additional feature support that I am aware of, other tan Launch and Flat Foot Shift similar to OFT , suspect its same software patch as OFT You can self tune with BRZedit If comes in several user levels The software is licienced to one Tactrix Adapter The cheaper versions of BRZedit are also locked to one vehicle via the VIN More expensive Tuner version for $450 allows flashing of multiple cars. Laptop required to log and flash Has some tuner support depends on country You need Brzedit software cheapest is $100 USD ( only allows flash no edit) or the $150 version if you want edit ability plus a Tactrix adapter to flash $170 so about $270 - $320 USD (no tunes supplied) www.brzedit.com Some brzedit tuners have written code or have access to flex fuel, overboost cut launch and Flat foot shift features Ecutek More expensive system especially if you purchase cable kit. Has good support from many tuners and Ecutek support the tune system well. Ecutek are only people I am aware of that offer an ecu “unbricking” service Has advanced features including alteration to the actual ecu program to add many extra features not just launch or flat foot shift, 4 way map switching such as flex fuel , speed density tuning and other safety features for higher boost applications The Launch and Flat Foot shift have many adjustable parameters and work better than the OFT or BrzEdit lc\ffs Uses a different encryption/lock system than BRZedit so not interchangeable ECU is locked once an Ecutek tune is flashed Ecu can be unlocked by flashing back a “stock” rom Flash licences not transferable only cable kit can be on sold Tunes from tuners are generally locked and not viewable or editable You can tune yourself with ecutek, but for full racerom feature access you will need to buy additional RaceRom extension. Laptop required to log and flash. Ecutek supply the tune system but they do not tune. You need to go to an Ecutek tuner for a tune and flash licences or to buy cable kits. The cable kit can be used to flash or log multiple cars but you need a ECU licience for each car you want to flash The cable kit can log and clear/read DTC on a car without a Ecutek licience in ECU If you buy a tune from a tuner it will have access to all racerom features like map switch, SD tuning ,custom maps etc. If you self tune the basic proECU software only gives access to the basic RaceRom features like launch and flat foot shift. You cannot access stuf like 4 map switching you can only access Map 1 tables and you dont get access to custom maps SD tunnig and a lot of other high end features. If you want that as a self tuner you need to buy the RaceRom extension pack for another $350. even with RaceRom extension you cannot access locked tunes, it just allows you to add in those features to a tune you make yourself. You need Ecutek cable kit $350 (if you want to flash tunes yourself) Ecutek ECU licience (1 per car) $350 Tunes not supplied tunes start from 100-500 or so USD If you want full access tune/modify all Race Rom Features add the Rece Rom extension for about $350 More info http://www.ft86club.com/forums/showthread.php?t=117520http://www.ft86club.com/forums/showthread.php?t=117520 www.ecutek.com Other systems less popular HKS Flash Editor Aparantly locks ECU to that system Know nothing about it differnt lock system to brzedit or ecutek Vivid Racing Genius I know nothing about it other that what in thread below http://www.ft86club.com/forums/showthread.php?t=103014 UniChip I know little about it It a piggyback ECU system ie it requires wiring. Piggyback systems work by intercepting some sensor inputs to the Original ECU and then processing them and presenting the modified sensor reading to the original ECU. They are popular on cars where the original ECU is not easily flashable or has not been "cracked" to allow flashing Piggy backs are limited in their adjustments compared to flash systems. Unichip was more popular in early days with BRZ/86 before the flash systems had "cracked" ecu to allow flashing of the original ECU code and tables. http://www.unichip.us/vehicle/vehicl...Subaru-BRZ-20L http://www.ft86club.com/forums/showthread.php?t=25211 |
Could you add this to the sticky at the top?
http://www.ft86club.com/forums/showthread.php?t=29340 |
I believe also that EcuTek Master Tuners have more access and options for tuning with EcuTek. But if you have a good relationship with a MasterTuner company you may be able to go through them if you want tune your own vehicle.
BTW, IIRC there appeared another tuning system via MyGenius device, just for listing sake. But while OFT/Ecutek both have good and bad points, i don't see good in this. It's locked and priced like Ecutek, but isn't as widely used/known by tuning shops like Ecutek is, which justifies Ecutek price. Also not offset by openness of tunes and big community behind as for OFT. I guess it will still gains over stock, but i don't see how it may be competitive enough vs other offerings unless they aggressively drop price of that device+tune to OFT or below level.
Is it possible for real time sensor data with the Tactrix/Ecuflash and can the BRZ edit software be used on tablets?
Unichip also has a system for the FT86.
www.unichip.com You can get a Motec M150 through Full Blown which totally replaces the ECU. |
Awesome! Should be a sticky
Also, is there a tuner that does single function changes? Like I want to change the voltage values on my throttle for quicker response. I don't want a full tune just to do one thing. |
I think this should do it. Inexpensive too. You sure it works on the 86? Its not on their car list. |
Unfortunatly romraider logger ie tge opensource logger has not been updated to work with brz\86. So you would have to by the base brzedit software for 100 usd to log realtine with tactrix. It should run on a windows tablet but best ask the brzedit guys |
http://www.epifansoft.com/brzEdit-video-tutorials.html it looks like it can do "dashboard" type displays , should work on a modern windows tablet |
After watching the videos on their site, some features of brzedit appear very powerful, esp. logging+vdyno.
I would love to give Brzedit a try, but according to @epifan in this post, saved files are not compatible with RomRaider any more. And after reading the thread, I still could not determine, if Brzedit generally locks the ecu. Compatibility to open-source solutions is a must to prevent vendor lock-in. And I would like not to block the path of using an OFT if I eventually pick one up in the future. Can I edit a rom with Brzedit (personal version) and flash it via Open Flash Tablet? |
| All times are GMT -4. The time now is 07:41 PM. |
User Alert System provided by
