-   -   More Horsepower! (https://www.ft86club.com/forums/showthread.php?t=105470)
mdm 05-08-2016 01:48 PM
Originally Posted by billwot (Post 2646316)
Look at the equation...an increase in torque will result in an increase in HP at any RPM. It's a mathematical certainty.
I meant that an increase of torque does not mean that the maximum hp (which people usually refer to as it is published) will necessarily increase. In cases I mentioned it may remain the same or even decrease.
Celica00 05-08-2016 01:55 PM
So higher HP throughout the powerband but not more maximum HP necessarily?
mdm 05-08-2016 02:14 PM
Here is an example. Imagine an engine that has exactly 150 lbft from 1000 to 7000 rpm and revs up to 7000. (I know no engine is exactly like that, it's a simplified example to demonstrate the idea). The hp is 29 @ 1000 rpm, 86@3000, 143@5000 and 200@7000. Max hp is 200.
Now we increase torque to 200 lbft but only in the low rpm range. Eg. 200 lbft from 1000 to 3000, 180@4000, 160@ 5000 and 150 above that. The hp is now 38@1000, 114@3000, 152@5000 and still 200@7000. So while max torque increased to 200 lbft, max hp is still 200.
Another example: we increase torque to 170 lbft across the rpm range, but now the engine can only rev to 6000. Power is now 32hp@1000, 97@3000, 162@5000 and 194@6000. And that's the maximum hp now, 194 with 170 lbft max torque.
VTEC 05-08-2016 03:03 PM
Originally Posted by Doubletap (Post 2646254)
I'd rather have more torque. The HP on this car is fine.
Agree. I find this engine quite peppy between 4500 and 7400 RPM. But getting this car off the line quickly needs a fairly aggressive release of the clutch and traction control turned off
Teseo 05-08-2016 03:35 PM
I want more "aggresive" wheels and aeoro-kit.
Tcoat 05-08-2016 04:46 PM
Give it 50 more and you will still hear "but the XXXX sedan has 50 more" and "this car needs anther 200 to keep up with the YYYY".
What I would do with 50 more is probably nothing. I can already be above any speed limit in between 3 and 7 seconds (without bouncing off the rev limiter or even going to 7k). I do not need to trim .2 seconds off my time from stop light or the traffic in front of me.
billwot 05-08-2016 05:12 PM
:thanks::thumbsup:
seito23 05-08-2016 05:21 PM
Originally Posted by JD001 (Post 2646304)
I would take the extra 50bhp and stick it in trunk saving it for a rainy day.
I see what you did there
themadscientist 05-08-2016 09:11 PM
250hp would be better, but as so has astutely been pointed out, low end grunt would be much more beneficial. Being able to accelerate stronger out of corners and sprint better to the next one would really hone the working edge of this car into a sharper weapon. As it sits it will do 100mph in fourth, I have no speed complaints, just acceleration ones and that's a torque problem.
I know when it lays down between 3500 and 4500 I think, "man, feel that fuel economy!"
airjonny 05-08-2016 09:56 PM
Fast car Fast> Slow car Fast > Fast car Slow
krayzie 05-08-2016 10:18 PM
So to answer the OP, with 50% more horsepower I would use it to trash the stock components of the car that weren't design to support an output of 300hp.
themadscientist 05-09-2016 01:19 AM
http://s2.quickmeme.com/img/ed/ed1d5...aa671d4bd2.jpg
Mim 05-09-2016 01:56 AM
Or you could just upgrade your diff ratio, add Crawford power blocks and call it a day.
This would speed up every gear and move the entire power band down a few hundred RPM. This is assuming you are staying NA and just want to improve DD drivability. Depending on the FD ratio I'd imagine this combo would (seat of the pants wise) get you pretty damn close to the feeling of having those 50 extra ponies.
themadscientist 05-09-2016 02:25 AM
If it's destined for the twisties or autocross, this might be a great trick.
