-   -   Wifi in a detached garage (https://www.ft86club.com/forums/showthread.php?t=103844)
Irace86 04-02-2016 02:00 AM
Is it possible? If my detached garage is maybe 50-100 feet away from my place, can I get wifi from my home?
--The electricity in the garage is not shared with my unit
--There is not a direct line of sight from my unit to the garage
--There is no chance of a repeater, satellite, antenna or other exterior add on; everything must be indoors
What are my options? Is there something that can get me online in the garage?
Tcoat 04-02-2016 11:42 AM
I read that title wrong and had all sorts of tips for you. Then I realized it said wifi.
http://i4.mirror.co.uk/incoming/arti...le-Charity.jpg
Vampyre 04-02-2016 12:06 PM
It may reach. I get wifi all over my 1/3 acre lot while mowing the yard. The listed range for 2.4Ghz wifi is 66 ft indoors and a bit further out doors.
EddieBRZ 04-02-2016 12:17 PM
Have you tested the modem router in the house at the closest spot to the garage? That's not a very long distance so any decent router should reach, only really being affected by brick walls slightly.
Leonardo 04-02-2016 12:38 PM
You can "daisy chain" routers. You may have to add one in the garage. This is what I did in mine. I run the new 802.11ac linksys. (2 of em)
Who8myrice 04-02-2016 01:03 PM
This might be best way. You will lose some speed but unless your going professional video gaming won't matter.
Irace86 04-02-2016 02:40 PM
i think i have an extra router. i'll see if i can pick up the signal with that from the garage.
we live in a dead spot, so i use wifi to make and receive calls/texts, so i want it for that when i am in the garage and to hop on the internet if i need to research something while working on a garage project.
bee-jay 04-02-2016 10:58 PM
look at http://www.engeniustech.com/ i use their equipment at work an at home with good success for range and power. lots of options to choose from based on above recommendations. range boosters, single unit, outdoor access points, bridges etc.
I use a single access point and get awesome signal in my garage which is at least 150 ft from the router in the house.
http://www.engeniustech.com/products...t-bridges.html
Irace86 04-02-2016 11:14 PM
Those look cool. I was curious if just an antenna would work. It would have to be inside. Nothing can go outside my unit.
Ultramaroon 04-03-2016 03:25 AM
Just look for "directional" or "high gain" antennas. Google "cantenna." That should give you some ideas.
Tcoat 04-03-2016 03:31 AM
Do NOT image search "daisy chain"!!!!!!!
soulreapersteve 04-03-2016 03:49 AM
Especially at work, with your boss sitting near you!!!
Irace86 04-03-2016 12:30 PM
Everything on the Internet leads to porn eventually
Ashikabi 04-04-2016 09:11 AM
A range booster and a second router should be the answer if there is one
