-   Issues | Warranty | Recalls / TSB (https://www.ft86club.com/forums/forumdisplay.php?f=72)
-   -   Burning clutch smell in reverse... (https://www.ft86club.com/forums/showthread.php?t=103224)
softgrip 03-20-2016 08:23 PM
I have a VERY narrow driveway on a hill. I have bend in it with a massive tree (1m diameter) one side, and an unforgiving rock wall on the other. There is less than 1/2 foot clearance either side of my car. Because of the nature of this driveway, reversing takes patience, concentration and a whole lot of clutch play.
In my WRX I had no problem, but in this BRZ my car smells like an egg factory by the time I get out. I'm using the same technique.
I hope I'm not damaging the car :/. I'm not sure there is a way I can modify my driving. I've been reversing out of this driveway for 15 years!
* hah from using search... Perhaps this is normal?!
Ultramaroon 03-20-2016 08:26 PM
How many miles on the car?
Lelantas 03-20-2016 08:26 PM
Reverse in to the driveway instead and drive straight out? Without seeing exactly what the situation is like, that sounds like the simplest solution.
extrashaky 03-20-2016 08:34 PM
Looking at your post history it seems you just recently got the car. So yes, that smell is normal for a new twin. The clutch may stink for a few thousand miles, especially when you're in a situation that requires a lot of slip. But once it's fully worn in it will stop.
This car has a lot of weird quirks that are actually normal. If you want to get really, really drunk, read through this forum with a bottle of your favorite liquor in front of you and take a shot every time you see a reference to something being normal.
softgrip 03-20-2016 08:46 PM
700km
softgrip 03-20-2016 08:48 PM
Oh god no - that would be 100 times more difficult :). It's not an easy driveway, but I'm doing it the easiest way possible.
Ultramaroon 03-20-2016 09:34 PM
Originally Posted by softgrip (Post 2590114)
700km
Yeah, it's still burning off the cutting fluids and fingerprints.
Rustyspoon 03-21-2016 01:46 AM
had a similar situation with the backing in of a fairly aggressive slope. Clutch smell goes away when car has some mileage on it!
UNCC_BRZ 03-21-2016 08:44 AM
You could cut down the tree get the stump removed and make your driveway straight....
krayzie 03-22-2016 06:06 AM
When I got my clutch upgraded at 15000km the stock clutch looked like it's new even with all that smell. I wouldn't worry about it.
lowlevel 03-21-2017 05:41 PM
Hmm, interesting... I too have just smelled burning clutch while parking with what seemed to be not an excessive amount of slipping and relatively early at about 2500km on the odo. In my case, kind of up a slope and around garage crap... hoping by around 5,000km+ I never smell it again... *cheers*
Xxyion 03-21-2017 06:38 PM
If its steep enough couldnt you just throw it in neutral and coast it?
