-   Suspension | Chassis | Brakes -- Sponsored by 949 Racing (https://www.ft86club.com/forums/forumdisplay.php?f=59)
-   -   TRD Springs installation. (https://www.ft86club.com/forums/showthread.php?t=102570)
phantasticity 03-07-2016 04:05 PM
I've called multiple shops to check on the prices of installing the TRD springs, all I'm getting is $600-800, the lowest I got was 350 w/o alignment, but that shop looks shady. Is 600-800 normal prices or do you guys think I can find someone to do it for a lower price? I can't DIY because I'm not experienced and donesn't wanna mess up my car.
PS: I'm in the BAY area.
go_a_way1 03-07-2016 04:09 PM
Its a easy DIY you just need to rent a spring compressor from a part store.
otherwise be prepared to pay at least 2 hours labor =$280 here + $140 for alignment = $420. Thats if its only a 2 hour book job.
wparsons 03-07-2016 04:21 PM
I think most places charge 0.75-1 hour per corner, but a shop going by actual time could be way less. Assuming nothing is seized or needing to be cut off it should be 0.5 hours per corner max.
funwheeldrive 03-07-2016 04:24 PM
Check with Neal @The Racers Line. He is local and knows our cars well. I don't think he does alignment, but he can probably point you in the right direction.
LXXXV1 03-07-2016 06:31 PM
$600-$800 is ridiculous. Might as well get coils at that price range. $200 tops.
Bykov 03-07-2016 08:28 PM
Spring compressors are quite cheap. I would invest in them and do the job yourself then just worry about getting an alignment after the fact. It is a really easy job.
Toyota quoted me $1200 installed including the springs at $240 from their parts department.
Kestrel 03-07-2016 08:58 PM
No spring compressor needed
http://www.ft86club.com/forums/showthread.php?t=32414
Just followed this guide along with the other DIY linked within and it was completely painless. You'll feel silly you contemplated giving someone money to do it.
Bykov 03-07-2016 09:05 PM
This is what I did for someone else's car but I still have spring compressors because they're $40 so meh.
Kestrel 03-07-2016 09:15 PM
They're great to have when you need them, that's for sure. It would just be a waste of time on this particular vehicle. Out of the 2 or 3 other cars I've lowered this was just so straight forward. The forum members helping each other out really pays off. :thumbup:
Cole 03-07-2016 09:17 PM
I also did my springs like that
jawn 03-07-2016 09:19 PM
Me three.
strat61caster 03-07-2016 09:58 PM
LA is an anomaly when it comes to living in a populated expensive areas and auto-mechanic labor rates. Where OP is I wouldn't be surprised if average labor rates have climbed to $150/hour.
Bill a 3 hour job, $150/hour, $200 for an alignment, boom $600 spring install.
I'm curious to hear what Racer's Line would charge, good reputation for being honest and it's an easy install on this car, aside from a jack and jackstands it can all be done with simple hand tools and if no adjustment components are installed or disturbed an alignment is unnecessary.
weederr33 03-08-2016 12:04 AM
Just do it yourself. Seriously, I had never done any sort of suspension work when I installed my TRD springs. The instructions with them are crystal clear and the DIY page helps even more.
zc06_kisstherain 03-08-2016 11:19 AM
yeah like others mentioned. do DIY.
start early in morning and take your time just in case you get stuck, you have time to finish it.
i one time started at 3:00pm on motor mounts and couldnt finish it because outside was darker. i finished it next morning. i will never do motor mounts again on RSX-S
