-   -   Winjet high beam getting stuck (https://www.ft86club.com/forums/showthread.php?t=102546)
Extremecheeto 03-07-2016 02:50 AM
Like the title says if I try to flash my high beams they get stuck and they will only go back to low beam if I turn the lights off and back on also sometimes one headlight will turn on with the high beam and the other will be low beam but that hasn't happened since I adjusted them to normal height. Has anyone else had this problem?
Kritsada 03-10-2016 03:05 PM
I have the same problem with my driver winjet headlight. I contacted fteightysix where I bought the headlights from and they were able to get winjet to ship out a replacement headlight. I probably won't be installing it as it takes time and I just dipped my car. It usually goes away after 15-20 minutes so it doesn't bother me all the much. Good luck.
go_a_way1 03-10-2016 03:06 PM
This is a normal thing with aftermarket headlights. My spec-d's do the something
